Main > Everything Else
carbon monoxide in house
Pages: << < (2/4) > >>
shardian:
Everyone should have CO detectors, especially if you have an attached garage. I recommend the hard-wired version with battery backup.
Definitely get a professional to check that out.
squirrellydw:
yeah, everything seems ok now.  We had the fire dept come out and look.  We have  two CO detectors and they were going off the other day when I posted this.  The fire dept said one was bad so I should replace it.  They checked the house and only found it in the garage.
RayB:
Is there any thread where Chad doesn't have an opinion? I swear Chad you need to put a legal disclaimer in your sig.
ChadTower:
Erm, you don't like when I advise the guy not to let his family sleep in a house where carbon monoxide is present?
What exactly is wrong with that?   :dunno
RayB:
You're stating the obvious Chad.  You're suggesting he install detectors. Well how would he know he had carbon monoxide build up in the first place if he didn't have detectors? You do know it's odorless right??
Go to full version
