Author Topic: Grandtec Ultimate XP Pro impressions needed  (Read 1063 times)
Bluedeath
  • Last login:June 19, 2014, 11:20:09 am
« on: December 09, 2006, 07:33:49 am »
I'm planning to buy one of theese to interface my pc to a 25" TV using RGB SCART cable, is that a good idea?
Did one of you guys is already using one?
Are you satified with the picture quality?
I give up  fighting keyboard dislexia, I lost.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: Grandtec Ultimate XP Pro impressions needed
« Reply #1 on: December 09, 2006, 07:36:26 pm »
Sorry... Have you got a link to show us what one of these is???
You can't normally interface a PC directly to a TV Set that way... because the RGB on the SCART runs at a different frequncy to RGB signal from a PC.
I guess you're somewhere in the UK if you're using a SCART lead. I'm very interested in this devce you mention if it allows that to be done. I have a TV frequency RGB Monitor.... effectively an arcade monitor with a case I was thinking about using, but I don't want the expense of an Arcade VGA Card.... which as far as I know at the moment is the only way to get a high quality, correct resolution, image.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
Bluedeath
« Reply #2 on: December 09, 2006, 09:29:36 pm »
is a unit that does the dirty job of trasnforming the 31khz into 15khz by using a digital framebuffer.
I've seen it around and i was, How it works.
Fozzy The Bear
« Reply #3 on: December 09, 2006, 09:33:56 pm »
OK.... So I guess we both need to know what the quality of output is like and if it will work with the setup we have.
As I said, if you can provide a web link to the device, then that would be a help here.
Best Regards,
crashwg
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
southpaw13
  • Last login:October 31, 2020, 05:11:18 pm
  • Whatever!
« Reply #5 on: December 09, 2006, 11:42:41 pm »
I had an older one with the same name and the emulation would not stay synced at times (image would tear)...
Buyer beware..
Fozzy The Bear
« Reply #6 on: December 10, 2006, 06:58:58 am »
Buyer beware..
Thanks for the info! I suspected that might be the case, given that we're dropping the output frequency so much.
Best Regards,
