Author Topic: LCD top gun hack idea  (Read 2369 times)
Bluedeath
  • Last login:June 19, 2014, 11:20:09 am
« on: December 06, 2006, 05:37:00 pm »
HI to all i just bought 3 new guns, my intention is to gut  2 of em and put the camera of the gun inside into a different Case (im' planning to use some cheap airsoft guns with the intrior removed).
MY options are:
2 shotgun (as HOTD3)
2 UZIS or mini Uzis (as op thunderbolt/T2/revolutionX, but the real playing expereince will be more like warzaid i think)
2 H&K mp5
Other options suggestion from you are welcome
Which one do you guys think is the best option? Should i mix the gun I.E. 1 UZI and 1 shotgun?
« Last Edit: December 06, 2006, 05:39:05 pm by Bluedeath »
I give up  fighting keyboard dislexia, I lost.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: LCD top gun hack idea
« Reply #1 on: December 06, 2006, 07:09:36 pm »
Why use cheap airsoft guns.... I hacked one of mine into a genuine (deactivated) Sterling L2A3 Sub Machine Gun.  Removed the electric recoil motor and fitted a non latching relay in its place, then attached that to a huge pinball coil inside the rear end of the gun that really kicks the bolt back. Powered the whole thing from a retired arcade power supply that gives the recoil enough amps to kick.
It's great fun!!
I'm working on a lens modification that will alow shorter distance between the gun and the screen as well.
Best Regards,
Julian (Fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
« Reply #2 on: December 06, 2006, 09:47:24 pm »
I love the idea although I don't know how to do that.
The MP5's are awesome in the firing range but I haven't seen the airsoft version to compare.
There are three kinds of people in the world those that can count and those that can't.
Bluedeath
« Reply #3 on: December 07, 2006, 03:03:20 am »
It's great fun!!
Best Regards,
I'm  a bit on low budget so cheap softairs are my only options, as alternative solution  I've found a metal replica of the UZI (OP wolf type)at 20 € but i like the shape of the MP5 cause i like the more ergonomic shape, metal replica are great but heavy so you cannot play for a long time without getting  your arms tired.
To shorten the distance between the screen and the gun i'm planning to use a wide angle lens taken for a mobile phone camera upgrade kit, do U think that this is a good idea?
« Last Edit: December 07, 2006, 03:07:36 am by Bluedeath »
Firebaall
  • Last login:May 01, 2011, 11:26:24 am
« Reply #4 on: December 09, 2006, 12:25:04 pm »
Neat Idea Fozzy.
I have a question, that you might be able to answer.  How high of a voltage do you think you could feed into the stock recoil coil?
USB=5V
I have an AC/DC adapter that puts a wide range out @ 1700mA.  I would assume 6V is safe, but how much would be too much.  ;)
Fozzy The Bear
« Reply #5 on: December 09, 2006, 05:58:16 pm »
USB=5V
The standard recoil on the LCD Topgun isn't a recoil coil! It's an electric motor that drives the topslide back through a set of gears.
I'd strongly recommend against using anything other than the 5V DC specified by the manufacturer. I don't think there is any internal voltage regulation in there. You can pull a high ampage +5V and Ground, direct from your PC power supply.
Best Regards,
« Last Edit: December 09, 2006, 06:06:00 pm by Fozzy The Bear »
Fozzy The Bear
« Reply #6 on: December 09, 2006, 06:02:44 pm »
Been there! Tried that! Got the T-shirt!......
It won't work, because of the fisheye distortion you'll get from that lens setup. You also need a further lens system to remove the problem, and that's when it starts to get very expensive. The problem I'm finding, is that to work effectively, the lenses have to be as near to optically perfect as possible and that's what costs the big bucks.
Still on the case with that one....... You could give it a try and see if you get a better result than I did though.
Best Regards,
« Last Edit: December 09, 2006, 09:36:42 pm by Fozzy The Bear »
Firebaall
« Reply #7 on: December 09, 2006, 07:23:33 pm »
Thanks for the pointer.
I was concerned with drawing the +5 volts DC from an Xbox port (600mA was too high of a current draw), when not using a PC.
I'll have my multimedia PC beside the xbox anyways, so I'll just convert a molex to feed the guns right from the PC's power supply.  :)
Lilwolf
« Reply #8 on: December 11, 2006, 10:44:18 am »
So, are we going to see any picts of the hack?
I would LOVE to see it!
