Author Topic: Wow it's cold! Is it OK to cut, glue and paint in this weather?  (Read 1941 times)
  • Last login:Today at 07:54:28 pm
« on: December 06, 2006, 09:34:17 am »
I'm in northern NJ and this week the temperatures have dropped pretty drastically - it's cold out there!!  Anyway, I was wondering whether or not it is OK to proceed with building my cabinet out in the unheated garage.  I can always bundle up to keep warm but what I'm really concerned about is whether or not wood glue will dry properly and if I take my time whether or not I can get a real nice painted finish.
I don't want to wait until March to keep working!!!  Any thoughts?
Re: Wow it's cold! Is it OK to cut, glue and paint in this weather?
« Reply #1 on: December 06, 2006, 09:37:24 am »
Depends on how cold it gets in your garage.  If it's in the 50s, you may be able to get away with it.  If it's in the 30s, forget it.  Your paint/glue will partially freeze and your tools/materials will start snapping instead of cutting.
shardian
« Reply #2 on: December 06, 2006, 09:38:41 am »
There are usually temperature warnings/guidelines on the label of the paint and glue. Give them a read. I believe 50 degrees is the cut-off for painting.
« Reply #3 on: December 06, 2006, 09:40:53 am »
And at 50 degrees the set/dry time will take A LOT LONGER.  If it says 50 degrees, I'd say the cutoff should be 60.  50 would work for stuff that doesn't need to be pretty, but not things you want with an optimal finish on it.
Kaytrim
  • I'm too nice a guy
« Reply #4 on: December 06, 2006, 09:44:23 am »
Just build yourself an insulated paint booth in the garage and get a small electric space heater.   ;D  I would strongly suggest you not get a propane heater unless you are building a bomb using paint fumes.   :timebomb:
« Reply #5 on: December 06, 2006, 09:45:47 am »
Build a cab to build a cab.   :)
If he gets a decent space heater for his garage it should be enough for the short term unless it's a really big garage.
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
« Reply #6 on: December 06, 2006, 10:33:46 am »
A couple winters ago I worked on my cab in a garage in Toronto until I realized that I was using a circular saw and my hands were completely numb.  Not entirely safe.  Needless to say, I waited til spring.
pointdablame
  • Last login:November 09, 2023, 09:11:07 pm
« Reply #7 on: December 06, 2006, 10:34:44 am »
As a fellow northern NJ resident, I know exactly what you are talking about.
I would NOT glue or paint anything right now in an unheated garage.  As sad as it may be, you're probably better off waiting for warmer weather, otherwise your results will likely be pretty poor.
first off your and idiot
« Reply #8 on: December 06, 2006, 11:02:12 am »
Hmmm... not the answers I was hoping for but pretty much what I thought.  My garage is detached from the house and it fits 2 cars (barely).  It is definitely a little warmer in there than outside but I can still see my breath.  I'm going to lug my tools inside tonight and bring them out only when I need to work and I'll be storing the paint inside as well until I'm ready to use it.  I think I'll pick up a space heater this weekend and see if that makes a difference.
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #9 on: December 06, 2006, 12:46:48 pm »
I'm in eastern PA, and winter time is project time for me. ;D
My garage is attached, but not heated. Get one of those double headed heaters that go on a propane tank. Let it run for 45 minutes to an hour before you go out. Keep your paint indoors until you're ready to paint.
If you'd like to work with the door cracked, a kerosene/electric "torpedo" heater might also be  good for you. I have a 115,000 BTU heater that can warm a garage your size in a few minutes.
« Reply #10 on: December 06, 2006, 12:52:47 pm »
Enclosed fumes + kerosene/propane may be a bad idea.
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #11 on: December 06, 2006, 12:59:12 pm »
  I'll get the marshmallows!
Kaytrim
Re: Wow it's cold! Is it OK to cut, glu fore and paint in this weather?
« Reply #12 on: December 06, 2006, 01:23:50 pm »
 :timebomb:   :timebomb:   :timebomb:   :timebomb:   :timebomb:   :timebomb:
That is why I recommended an electric heater.  Here is the type of heater that NASA uses on the shuttle.  http://www.pelonis.com/discfurn.htm  They are very concerned about fire in space.  These little things put out quite a bit if heat too for their size.  They have one that is 7" cubed and puts out 5,200 BTU.  They are rather inexpensive too Ace Hardware has the cube model (HC-451) for about $80
TOK
« Reply #13 on: December 06, 2006, 01:50:30 pm »
I haven't blown myself up yet, and I've been doing it for 20 years.  ;D
« Reply #14 on: December 06, 2006, 01:52:45 pm »
Your avatar indicates otherwise, bro.   :laugh2:
TOK
« Reply #15 on: December 06, 2006, 01:52:57 pm »
I have one of those, it's great for keeping your hands warm while the rest of the garage is 40 degrees.
TOK
« Reply #16 on: December 06, 2006, 01:54:24 pm »
Ahem, I said I haven't blown *MYSELF* up.  ;D
« Reply #17 on: December 06, 2006, 01:57:51 pm »
I see your silhouette in the flame.
TOK
« Reply #18 on: December 06, 2006, 02:00:37 pm »
It warmed up the garage nicely, and I saved 75 cents in kerosene that day. I think it was worth it!
TOK
« Reply #19 on: December 06, 2006, 02:09:17 pm »
OK, enough goofing around Chad.   ;D
Although the kerosene electric works fine for me with the door cracked, I can see some guys not wanting to do that. Reddy makes a ventless propane heater that will heat a two car garage.
This is the same company that makes my kero/electric heater and it's been great.
http://www.reddyheat.com/productType.cgi?type=1
After looking at them, I actually might go get one of these. I really like the way it wall mounts.
« Reply #20 on: December 08, 2006, 10:22:27 am »
I think I'm going to look into getting a heater for the garage... I really want to work this weekend but it is really cold outside - 21 degrees with a high of 32.  How expensive are these things?  Can I get something adequate for under $100?
« Reply #21 on: December 08, 2006, 10:32:31 am »
Probably depending on your garage but remember, you don't only have to run it while you work, you have to run it for the entire duration of material drying.  So paint, glue, etc all need to stay a reasonable temp.  That isn't going to be cheap.
