Author Topic: Need some help with Suzuka 8 Hours 2  (Read 1104 times)
ad4nu
  • Last login:April 16, 2007, 10:46:48 am
« on: December 04, 2006, 11:36:58 pm »
I purchased a Suzuka 8 Hours 2 game and am looing for a manual.  Does anyone have a copy of the manual?  I would really appreciate some help.
Also, I can't get the two bikes to sync up to have head to head racing.  Any ideas.
Thanks.
Re: Need some help with Suzuka 8 Hours 2
« Reply #1 on: December 04, 2006, 11:49:30 pm »
You buy that at the St. Louis Auction Dec. 2nd?
Kevin Mullins
    • Me on Myspace
« Reply #2 on: December 05, 2006, 12:40:40 am »
Here's a schematic from Suzuka 8 Hours. Same setup as 2.
It's not a full manual, but it a start.
http://arcarc.xmission.com/PDF%20Arcade%20Manuals%20and%20Schematics/Suzuka%208Hours%20Schematics.pdf
As for the syncing issue. Look for a little board with relays on it.
Check ALL the connections on there.
If I remember correctly it has what looks kinda like computer IDE type cables.
Those tend to have alot of bad connection problems.
grantspain
  • Last login:Today at 12:22:48 pm
« Reply #3 on: December 05, 2006, 04:41:46 am »
also worth checking the dip switch/programming settings just incase some one has set the game up wrong
Drews Arcade
  • Last login:July 28, 2018, 01:15:02 am
« Reply #4 on: December 05, 2006, 06:45:37 am »
As I remember there is a switch in the back to link them internally (single cab) or externally (many cabs). Make sure its set to internally, and check the player set up. Be sure to have both players to have the same # of laps, and make sure they have using differnt color of bikes.
ad4nu
« Reply #5 on: December 05, 2006, 09:44:50 am »
I purchased this game in Lincoln, NE last month.
