Author Topic: Why does my computer do this every few days?  (Read 1746 times)
drmlvr
  • Last login:August 17, 2017, 12:20:04 am
« on: December 01, 2006, 11:55:25 am »
Got XP and every 7-10 days it kicks me out and says:
Boot disk error- insert floppy
Don't have a boot disk.  Any help or tips would help.  THANKS
Mike
Re: Why does my computer do this every few days?
« Reply #1 on: December 01, 2006, 11:56:05 am »
It's coming on to you.  Go with it.
sphetr2
  • Last login:February 08, 2009, 06:35:00 pm
  • black and white album
« Reply #2 on: December 01, 2006, 06:16:17 pm »
That is too hilarious....
Anyway, maybe you are booting your computer with a floppy in it? Back when I was a computer noob, I left a floppy in, and remember getting an error. I think the BIOS is set to booting from a floppy, and then it realizes that the floppy is not bootable, and shows that error.
When does this error show up? At boot or during your use of XP?
But judging by Chad's response, it would seem that he's had much experience with it, so perhaps you should take his advice.  ;D
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« Reply #3 on: December 01, 2006, 07:28:14 pm »
When did this start? Could it be the hard drive in its death throes?
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
AtomSmasher
    • Atomic-Train
« Reply #4 on: December 01, 2006, 07:38:51 pm »
agreed, could be the harddrive going bad.
drmlvr
« Reply #5 on: December 01, 2006, 08:19:09 pm »
[/quote]
[/quote]
NO disk is the floppy.  It started to do this recently on its own.  It just shows up during use of XP, sometimes every other week.  Otherwise everything works fine.  Boot, Shutdown, etc.
« Reply #6 on: December 01, 2006, 08:29:04 pm »
It happens when his leg has been pressing up against the case for too long.
quarterback
  • Last login:August 16, 2023, 10:51:41 pm
« Reply #7 on: December 01, 2006, 08:38:06 pm »
Don't confuse your boot disk with a floppy.  If you have a computer that 'boots up' from a 'disk' then you have a 'boot disk'.
What people are saying is that, since you're getting this error it's possible that your 'boot disk' (whatever hard drive that you have your operating system installed on) might be going bad.  If your hard drive goes bad then (frequently) the next bootable-item is your floppy drive, which would explain the message.
That being said, if this is happening WHILE you're in XP (which is what you imply) then there's something else weird going on because your computer shouldn't be prompting you to boot from a floppy (or any other device) while your OS is already running.
« Last Edit: December 02, 2006, 01:24:57 pm by quarterback »
-- Chad Tower
USSEnterprise
    • USS Odyssey
« Reply #8 on: December 01, 2006, 09:52:11 pm »
Do you get the message when the computer comes out of hibernation, should you use it?
drmlvr
« Reply #9 on: December 02, 2006, 12:45:01 am »
Now that you mentioned this.  I remember now that when it does give me this error, it is mostly when I leave the computer on overnight.   Maybe has something to do with the power save thing........???
« Last Edit: December 02, 2006, 12:53:00 am by drmlvr »
sphetr2
« Reply #10 on: December 03, 2006, 09:47:10 am »
Yes, and then the fan starts spinning like crazy.  :D
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #11 on: December 03, 2006, 01:01:54 pm »
The drive is going bad. Also check that the IDE cable is very securely attached.
Back up any important data you don't want to lose.
NO MORE!!
fredster
  • It's all good!
« Reply #12 on: December 04, 2006, 04:29:14 pm »
I had SCSI drive that did if it didn't reach a set RPM.  If it didn't hit that speed then it was not reading the drive.
It was screeching toward the end.  Poor thing.
Kevin Mullins
    • Me on Myspace
« Reply #13 on: December 05, 2006, 12:50:37 am »
I agree with what has already been mentioned a few times........ the hard-drive is on it's way out. Start shopping for a new one.
Backup all your data you don't want to lose.
Or slave in a new drive and copy stuff over before the old one dies for good.
It could last quite a long time, or it could come to a sudden stop and never work again.
fredster
  • It's all good!
« Reply #14 on: December 06, 2006, 04:36:30 pm »
Is there any software or proceedure to say put an identical drive and just make an image on the other drive?
One that has the boot sector, etc on it?
I have two stock computers. Both are identical. Same hardware/software/etc.
If I have say a segate 80gb drive and it's dying, can I get a Maxtor drive (100 gb or the same size) and copy the first computer's drive to it so that I don't have to re-install the drivers?
AtomSmasher
    • Atomic-Train
« Reply #15 on: December 06, 2006, 05:04:25 pm »
I've used Norton Ghost to do that.  It can make exact copies of harddrives, including boot sectors.
« Reply #16 on: December 06, 2006, 07:36:02 pm »
Put it in a Linux box.  Use dd.
