Author Topic: Sanyo 14" monitor hula  (Read 790 times)
inspector
« on: November 29, 2006, 01:43:43 pm »
The 14” Sanyo monitor has waves (hula) ~~~ going across the top and bottom of the screen (vertical mount), if it was horizontal, the sides would be doing the hula.  I have recapped the monitor, changed the flyback, replaced IC601, replaced the width coil and checked for burnt parts and traces: none. I cannot figure it out, I have spent countless hours trying to. Any help would be appreciated.
grantspain
  • Last login:Today at 12:22:48 pm
Re: Sanyo 14" monitor hula
« Reply #1 on: November 29, 2006, 06:36:19 pm »
maybe the ground is bad or more likely your transformer is too close to the yoke,what about the flo tube
inspector
« Reply #2 on: November 30, 2006, 12:31:14 pm »
I moved the transformer 3 feet away, it is not that. I also switched transformers, same problem. The Sanyo monitor is the only one that has this problem, I connect all of my monitors on my work bench. I also have the frame grounded, no problems. Can you give me a little more info on the flo tube?
hammad
  • Last login:August 14, 2011, 04:23:27 am
« Reply #3 on: November 30, 2006, 12:55:58 pm »
I am no expert , but my suggestion would be that you should change your power supply.I also had this type of problem and it was caused by power supply.
inspector
« Reply #4 on: December 01, 2006, 12:13:19 am »
The transformer is the power supply to the monitor, which I said had been changed. If you mean the game power supply, I already had changed that also.
Thanks for the input.
hammad
« Reply #5 on: December 01, 2006, 01:24:46 am »
I am talking about the arcade power supply which has +5v,+12v and -5v.
inspector
« Reply #6 on: December 01, 2006, 02:19:03 pm »
That is the game power supply(+5v,+12v,-5v) which I said had been replaced.
Replaced:
transformer,
game power supply,
flyback,
IC601,
width coil,
and installed all new caps.
I have connected multiple pcbs, same problem.
It is in the monitor, I am looking for someone who knows about the sanyo units.
