Main > Everything Else
Volume control in WinXP
RayB:
check your CDROM audio settings
Santoro:
--- Quote from: RayB on November 30, 2006, 12:04:00 pm ---check your CDROM audio settings
Vigo:
Are you are refering to the volume controls directly mounted on the cd-rom drive? That usually shouldn't matter with a newer computer.
crashwg:
You can adjust the volume of the .wav files with Start/Programs/Accessories/Entertainment/Sound Recorder
Just find the file you want to quieted down, load it up, hit "effects/decrease volume" a couple times then save the file when it's quiet enough for you.
I had to do that for a .wav of a train horn that WS FTP Pro plays when it's done transfering. It was extremely loud in comparison with everything else the computer outputs through the speakers.
Granted, you'll have to do this with each file that is too loud but it is a solution, just not a quick one...
RayB:
--- Quote from: Vigo on December 01, 2006, 10:48:37 am ---
There's sometimes volume settings in the drivers of the CDROM device. And also (more obviously) in the Windows settings...
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
