Main > Everything Else
Anyone here with CCTV security experience?
<< < (9/9)
Ken Layton:
I have not done an upgrade such as that, but I don't see why you couldn't use your existing cables. If you get a Lorex system like I linked in the previous post, you should be able to directly swap out the cameras and DVR and reuse the existing camera cables.
dkersten:
--- Quote from: ahofle on November 18, 2015, 12:05:18 am ---Ken, have you ever installed an upgraded DVR/camera system like 1080p/720p on existing coax/power cables from a 480p system?  That kit looks great but I already spent a ton of time/effort running the cabling around my house for an older system (connections look the same though).  I would love a resolution upgrade now that those have come down so far in price.
Back when I was working professionally in the home theater business, all the engineers/manufacturers I talked to said coax cable (rg58, rg59, rg6) has a limit of about 600 lines of resolution.  Unless the cameras are sending digital data over a coax line, I would say the answer would be no.  On one hand I would expect modern cameras to use purely digital signals, but on the other, I would ask why use coax cabling when cat5 would be a better medium for digital signals...
Ken Layton:
Pre-made coax cables come with the Lorex system. That's what I used installing my friend's system and I'm getting 1920 x 1080 resolution.
Ken Layton:
Lorex 8 camera 1080p resolution system just $499 at Costco:
http://www.costco.com/Lorex-8-Channel-HD-Analog-DVR-with-2TB-HDD%2c-8-1080p-Cameras-with-130'-Night-Vision.product.100218592.html
ahofle:
I picked up the 8 camera Lorex system a few weeks ago from Costco when it was on sale for $449.  Installed it over my existing wiring and I am very happy with the results.  My only minor complaint is that the leads attached to each camera are shorter than my older cameras, so I couldn't place them in the same spots, but other than that I'm very happy with it.  I'm surprised how excellent the quality is over 100 feet of analog cabling.
Navigation
Message Index
Previous page
Go to full version
