Author Topic: ledwiz only half works?? Powermame and AtomicFE  (Read 4381 times)
gamenut
  • Last login:January 05, 2010, 06:11:46 pm
« on: November 24, 2006, 10:18:29 pm »
Got my ledwiz in the cp today. Got it wired up and only player two buttons light up.
None of the others will light. currently using powermame and Atomicfe
Can some one tell me how to access the ledwiz files? I cant find files for ledwiz hardware.
Also, in atomicfe, what is "LEDWiz's Game Settings Folder"? I don't see it in the mame32b folders or in the atomicfe folders.
youki
  • Last login:November 19, 2016, 01:07:33 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: ledwiz only half works?? Powermame and AtomicFE
« Reply #1 on: November 25, 2006, 12:33:55 pm »
Hi,
Did you read tutorial about AtomicFE and Ledwiz?   Or the new AtomicFE documentation by Havok?.
Check the Documentation section of my website , i think you will find answer to your question more in depth.
Before configuring AtomicFE with AtomicManager to use LEdWiz , you have to run the tool : LedWizManager.
In that tool you have to give a Directory where the tool will generate config file for game.  So give an empty directory you made  and it will be the "LEDWiz's Game Settings Folder" .  All Ledwiz files will be generated in that directory.
then in AtomicManager, you make point the "LEDWiz's Game Settings Folder" to that directory too (it should be already correctly set after you use the ledwizmanager).
But all this is explained better in the HOW to guide for LEDWIZ  by Gonzobrian.  (on my website).
gamenut
« Reply #2 on: November 26, 2006, 12:18:47 am »
Thanks Youki, you rock!!! :cheers:
I can't read the HOW TO becuase i don't have microsoft office.
But i got it working for the games. :applaud:
Now i just have to figure out the animation editor.
gamenut
« Reply #3 on: November 26, 2006, 01:12:29 am »
Help!
I did the atomic keymanager and noww no buttons work in the front end.
How do i turn it off?
I have to shut off computer to get out of atomic.
Havok
  • Trade Count: (+17)
« Reply #4 on: November 26, 2006, 02:22:53 am »
Help!
You can delete the AtomicFe.key file in your AtomicFE installation directory. This will remove the new settings, and have it revert back to defaults, or just re-run the AtomicKeys.exe to reprogram the key mappings.
You can open it in Wordpad, which is standard with any Windows machine.
-Or-
I also cover much of the same information in my documentation (I did not know GonzoBrian was doing a HowTo at the time), available in Acrobat or HTML format. The link is in my sig...
        v
« Last Edit: November 26, 2006, 03:17:19 pm by Havok »
loadman
  • Last login:August 17, 2020, 03:23:55 am
    • MaLa
« Reply #5 on: November 26, 2006, 05:57:46 am »
        v
How may edits did it take to line up that arrow?  ;)
gamenut
« Reply #6 on: November 26, 2006, 12:32:58 pm »
Well i'm at home now on my laptop, and i'm able read all the docs.
What a great way to support atomic.
I have to say that i am impressed with all the help i have received and the ease of use with this front end.
It is obvious that you guys made this newbie friendly, as well as seriously customizable for not newbie.
thanks
Havok
« Reply #7 on: November 26, 2006, 03:18:01 pm »
Haha - that part I got first try. It's my grammar that's the real problem!
 :D
gamenut
« Reply #8 on: November 26, 2006, 04:32:22 pm »
One more question,
How do i change the button settings for plug n play.
None of my buttons work in plug n play
Havok
« Reply #9 on: November 26, 2006, 05:18:47 pm »
That's strange. Do they work if you don't use a plug and play module?
Also, how are you interfacing to the computer? Are you using a keyboard based encoder, or joystick\gamepad?
gamenut
« Reply #10 on: November 26, 2006, 09:20:46 pm »
Yeah they work fine during regular game play. Not all the roms i have downloaded work. But the ones that do work, the controls are fine.
I'm using mame default controls, and a keywiz.
When i turn on the plug n plays it goes to a defualt layout menu. The only plug n plays i have downloaded are nintendo 64,playstation1, and snes.
Those are the only ones listed.
My guess is i need to download the mame arcade plug n play to see the other games.
But when in the menu my joystick will move the selector, #1 will chose the selected game.
Once the game starts, the only thing that works is the esc key.
It does this if i'm using the CP or keyboard.
Any ideas?
youki
    • Atomic Front End
« Reply #11 on: November 27, 2006, 04:00:04 am »
Hi,
you mean the controls are correct in AtomicFE   , you can browse the list and choose the game.
But when the game runs you have no control?
Do you have this problem with all plug'n play modules you installed?
AtomicFE don't change key settings for emultors.  May be you have to configure Key for emulator. Pnp Module are configured to work in most of case, but may be due to a specificity of your config emulator settings we choose are bad for you.
Havok
« Reply #12 on: November 27, 2006, 07:10:25 am »
One thing to check is if the controls work when you fire up the emulator by itself?
gamenut
« Reply #13 on: November 27, 2006, 10:21:07 am »
right now i only have roms for ps1.
Today i'll get some for other pnp's and let you know
Havok
« Reply #14 on: November 27, 2006, 12:17:33 pm »
One other thing: are you using 49 way joysticks?
gamenut
« Reply #15 on: November 28, 2006, 10:18:14 am »
Ok,I installed youkis mame arcade pnp. The controls work fine. But not with angelscry arcades.
Still nothing wth ps1,n64 or snes.
I use happ 8way comp- joys.
I was using mame32b, downloaded mame110 and now more games work.
It took forever to go through the games and remove the ones that don't work.
Today i think i'm going to try some led animations. ;)
youki
    • Atomic Front End
« Reply #16 on: November 28, 2006, 10:30:01 am »
You have some utilities to help for that. Things like ROMCENTER or CLRMAME.  It checks rom according to your mame version.
But what kind of config are you trying to do?  I don't understand,  for mame, you want use Pnp modules or you are doing you own configuration with mame110 ?
Havok
« Reply #17 on: November 28, 2006, 10:43:56 am »
This sure sounds like you just need to configure the controls in the actual emulators. Since the emulator is included in the pnp module, it may be configured in a way that is not compatible (at least initially) with your setup. Try setting up the controls manually:
PS1
Run <AtomicFE Dir>\plugnplay\psx\psxfin.exe
Click on File, then Configuration.
Click on the Controllers Tab
Configure each control the way you would like it.
Click OK, then Exit
N64
Run <AtomicFE Dir>\plugnplay\nintendo64\Project64.exe
Click on Options, Controller Plugin
Define your controls, Click OK
Click File, then Exit.
SNES
Run Run <AtomicFE Dir>\plugnplay\snes\zsnesw.exe
Click on Config, Input #1
Choose Keyb\Gamepad
Click on each control, define it
Close Input #1, repeat for other inputs
Close zsnesw
Good luck!
gamenut
« Reply #18 on: November 29, 2006, 01:41:35 am »
WOW Havok,
Thanks,that worked perfectly! :applaud:
I really appreciate help you guys have given me.
Working with atomic is just fun!
Today i spent some time playing with the led animations. what an easy interface for that. :notworthy:
Havok
« Reply #19 on: November 29, 2006, 12:29:19 pm »
Cool, glad I could help. Now post some more pics of your wood!
 :D
gamenut
« Reply #20 on: November 29, 2006, 06:23:11 pm »
Okey-Dokey ;)
