Main > Main Forum
Imperial Trackball From Ebay Problems
foosguy27:
Geez I should have used this forum a LONG time ago. Thanks for all of the wondeful ideas. Ummm, BTW, I am using MAME32 the version .59. I am still using this version, because it plays NBA jams and all other games at a higher speed than the newer MAME32 versions do. Anyway, onto the trackball again. I have a little device that converts a PS2 plug to a USB plug. Would you suggest plugging in the converter and putting it in the USB port? I am willing to try anything. Also, how would I go about adjusting the Sensistivity? Do I do this in MAME32 or somewhere in my computers Control Panel? I have a feeling that you are exactly right, that the mouse port cannot handle, what a trackball is intended to do. I will wait to try the USB thing after hearing some replies on here (hopefully). Also, is anyone else out there using one of these E-bay PS2 Imperial trackballs? How are they working for you? And what did you do to help make them work better? Again, any help is greatly appreciated.
Brian
Chris:
The trackball sensitivity is under the Analog Controls menu. Start the game, press Tab, and go to Analog Controls.
--Chris
Ted_Striker:
I got an Imperial trackball and I like it. It wasn't from ebay (I bought it from Imperial) but it is the same unit. I have the ps2 type and had similiar problems as you. However all were cured by fiddling with the analog control setup. Runs like a champ when you get it tweaked in.
gtjoe:
Try replacing the encoder wheels from 24 teeth to 36 teeth
Check out
"Replacing Imperial PS/2 trackball encoder wheels"
bu Oscar on December 06, 2002
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=3760;start=0
There are pictures of the new encoders installed.
rampy:
What settings did you settle upon, if you don't mind sharing...
I just had a maddening experience with shuuz because the sensitivity was all out of wack...
thanks!
rampy
--- Quote from: Ted_Striker on March 28, 2003, 01:17:48 am ---I got an Imperial trackball and I like it. It wasn't from ebay (I bought it from Imperial) but it is the same unit. I have the ps2 type and had similiar problems as you. However all were cured by fiddling with the analog control setup. Runs like a champ when you get it tweaked in.
