Author Topic: What's wrong with Track & Field  (Read 1020 times)
More Cowbell
  • That's just dumb!
« on: November 16, 2006, 11:22:23 am »
I have a Mame cabinet that I want to play all of the Hyper Sports and Track & Field variations. Hyper Sports works like a champ but Track & Field is weird. When you tap both of the buttons you can only get up to about 850 or so, but if you tap only one button you can get up over 1000. Why is it cancelling itself when you tap two buttons quickly? This happens the same way on two different cabs so I know it's not the buttons.
I've got a fever...
fatfingers
  • Last login:January 26, 2015, 10:15:43 am
  • Got UltraStiks?™
Re: What's wrong with Track & Field
« Reply #1 on: November 16, 2006, 12:25:46 pm »
I have noticed the same thing for one button vs. two buttons.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
neil324
  • Last login:October 07, 2013, 03:53:50 am
« Reply #2 on: November 17, 2006, 10:48:34 am »
Yes same problem here to, its the right hand button for me just press this instead of the 2 in turns ???
fatfingers
  • Got UltraStiks?™
« Reply #3 on: November 17, 2006, 11:11:39 am »
I'm running MAME .106
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #4 on: November 17, 2006, 01:28:10 pm »
Could be MAME's accuracy spoiling the gameplay a little again. If the original game had issues with delays/buttons cancelling each other out then it may have transferred to the rom dump as well. This isn't definite, just a theory as to why this happens.
More Cowbell
  • That's just dumb!
« Reply #5 on: November 17, 2006, 01:30:25 pm »
I've run it in several versions of MAME so I'm guessing it is ROM related. I'm just hoping maybe someone has found a setting or something that helps.
I've got a fever...
ahofle
    • Arcade Ambience Project
« Reply #6 on: November 17, 2006, 06:15:45 pm »
Did you try the 'comb trick'?  I thought that was pretty much the only way to get good scores in that game.
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« Reply #7 on: November 17, 2006, 09:22:02 pm »
Kinda off topic but in my version, all the running events don't keep the top 3 times.  Any idea why??
I b**ch. People listen!!
ahofle
« Reply #8 on: November 18, 2006, 12:24:06 am »
What version of MAME?  High score support was removed recently.
RetroBorg
  • Last login:July 06, 2022, 09:22:13 am
« Reply #9 on: November 18, 2006, 02:24:18 am »
I'm not sure if things have changed in the latest versions of mame but I reckon you need the NVRAM files to save these.
squirrellydw
« Reply #10 on: November 18, 2006, 06:42:54 am »
What are NVRAM files and where can I get them?
RetroBorg
« Reply #11 on: November 18, 2006, 08:33:27 am »
I could be wrong about NVRAM files, there's a list here but nothing for Track and Field.
http://www.mameworld.net/highscore/nvramtest.htm
I was sure Track and Field needed these but now I'm not too sure, unfortunately I lost my entire mame collection recently in a computer accident.  :cry:
I'm sure there are much more learned MAME users here that can set you straight.
squirrellydw
« Reply #12 on: November 18, 2006, 01:03:41 pm »
The high scores work on the other versions of T&F I have but not the real version.  I am running the last version of PowerMame with a slighty old ROM set, .98 or 101 I think
