Main > Project Announcements
MrQuan's Arcade Project - Latest: TV repairs
TOK:
--- Quote from: (+_+) on November 16, 2006, 03:52:44 pm ---Nice job on the TV extraction and mount.
Had a question that makes me feel a little tardish. If you were running a mame launching app at 1024 X 768 and used it on a TV instead of a PC monitor, would the image be
a) Cut off due to the much lower resolution of the TV.
or
b) Shrunk and adjusted to fit.
On the TV in my cab, nothing would be displayed at that resolution. Image would be "scrambled".
Mine will display 800x600, but I leave it set at 640x480 on S-video input and 640x432 on component input.
theCoder:
Love the documented mess-ups. Not that I take pleasure in your problems, but I think we all learn more from others mistakes than their success. Good progress so far.
MrQuan:
or
I'm using an NVidia GeForce 7600GS, with HDTV output. This gives me two resolution settings, either 720 x 576 (the one I use) or 640 x 480, at either 50 or 60Hz. If I force a custom resolution, such as 1024 x 768, the output to the TV will still be 720 x 576, however I can push the screen bounds around with the mouse in Windows (like if you set a resolution too high on a laptop).
So, the NVidia card will always output 720x576 to my TV, but will allow some kinda virtual resolution stuff, all of which is useless for an arcade cabinet :P
MrQuan:
Just bought a RAM upgrade this weekend, my arcade PC is now:...
Motherboard
Asus P4P800-E Deluxe, Wireless Edition.
CPU
Socket 478, Intel Pentium 4 'Northwood' 3.06 GHz with Hyper-Threading. (Over-clocked at 10% to ~3.3GHz).
RAM
KING-MAX 1GB dual channel RAM (512MB x 2) DDR400 (PC3200)
Video adapter
Albatron, AGP 8x, NVidia GeForce 7600GS, 256MB RAM DDR2, VGA + DVI + TV output. (Component output used - 720 x 576 @ 60Hz).
Sound adapter
Creative Sound Blaster Audigy 2 ZS Platinum Pro.
This system runs most newer games smoothly on MAME 0.110 :) I'm running MameWah as the system shell - I used the Hiding Windows article from the BYOAC Wiki http://wiki.arcadecontrols.com/wiki/Hiding_Windows.
MrQuan:
MameWah Profile
I've done a bit of work on a profile for MameWah. I wanted it to be native 720x576, quite generic (MAME, ZSNES, etc etc), and un-cluttered. Here's a screenshot of it...
I've attached it as a zip incase anyone is interested (make sure you edit layout.lay in Notepad and change any relivent paths, and install the include font HemiHead ;)).
If you have any suggestions for improvement, let me know :)
