Author Topic: Wico 8way Actuators and springs  (Read 796 times)
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« on: November 15, 2006, 11:34:43 am »
Does anyone know how to build or get replacment Wico 8way Leafswitch Actuators and the springs.  I have four of these joysticks but only two have the actuators and springs.  I have been thinking of a way to build  them but haven't had any good ideas as of yet.
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
Re: Wico 8way Actuators and springs
« Reply #1 on: November 15, 2006, 12:01:23 pm »
spring was it been possible to buy in happ. Spring from competion joystick is compatible from P360. P360 base is the same  how Wico.
I can execute actuator's. You would have to pass dimensions.
read this
Chunce DeLeone
« Reply #2 on: November 15, 2006, 12:33:48 pm »
I will find the demensions for the actuator.  Some of the ones on that post look like they would work.......
As for the springs I don't think Happ has anything that will work.....
kowal
  • Suzo 4ever
« Reply #3 on: November 15, 2006, 12:46:43 pm »
Measure actuator which you have. You can also measure spring.
you have example here:
Chunce DeLeone
« Reply #4 on: November 15, 2006, 01:31:40 pm »
Thanks Budd....will do..
Chunce DeLeone
« Reply #5 on: November 16, 2006, 03:18:03 pm »
I appreciate the help but I ended up getting 4 wicos that were taken from a Smash TV cab on ebay last night,  so I won't be needing the actuators
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #6 on: November 18, 2006, 12:27:39 am »
I know Chunce doesn't need the springs anymore, but just to clear up the confusion:
Kowal:  Wico leafswitch joysticks don't use a main spring like the one in the P360 for handle resistance.  They use a rubber grommet, similar to the one one an original PacMan stick.  They do use a little tiny spring to keep downward pressure on the actuator- this spring is not available from Happ.  Wico microswitch joysticks do use a main spring; a P360 spring might make a good replacement for that one.
Anyone who's looking for them:  Replacement actuators and small springs, along with balltop handles and rubber grommets can all be purchased from Ponyboy in the Buy/Sell/Trade forum.
