Main > Main Forum
Marquee too bright!!!
Pages: << < (2/3) > >>
Chris:
Even if you spray-paint the rear plexi white, plenty of light will shine through it!
Carsten Carlos:
How many watt's has your lamp or fluorescent light? I've 18 Watt installed - though less would have been enough, too.
seaner:
A sheet of white mylar would also do the trick by diffusing the light more.  Double it up to cut down the light more?
Get a lower wattage tube?
MrTeamWork:
I don't know if it's this simple - but why not get a less radiant bulb?
s8n:
mine is sandwiched between 2 pieces of lexan, for the back piece i just left the white film on the lexan, but obviously peeled it off the front piece. my marquee is also printed like a decal, and that also has a paper backing.
Go to full version
