Main > Main Forum
To Apache: Product improvement
RobotronNut:
while playing discs of tron, i push and pull while turning the spinner. doesn't everybody?
saint:
I have to admit I never knew DOT let you aim up and down. I probably would have done much better at the game if I did!
Kremmit:
--- Quote from: saint on November 13, 2006, 08:34:18 pm ---I have to admit I never knew DOT let you aim up and down. I probably would have done much better at the game if I did!
You only use it in later levels, so you have to be fairly good to even get a chance to try it.
Xiaou2:
For those who like to hack...
You may try drill out the existing roller on a roller switch... then
replace it with a nylon roller... or plastic bead of some sort. Of
course having to re-pin it togeter with maybe a watch shaft
or simular..
Again.. a pedal hack may be a great option instead... for those
with a non- up/down spinner.
Saint, I believe its either level 6 or 7 that enables up/down aiming
on DOT. Try using a cheat to get there if needed.
RayB:
--- Quote from: erictrumpet on November 12, 2006, 01:21:57 pm ---Boy, we arcade builder hobbyist types sometimes go a little overboard with the pre-purchase research don't we? :) I am very guilty of this as well! This BYOAC board is awesome and the comeraderie can't be beat, but sometimes it makes us suffer from "Too Much Information" syndrome. :)
I'd agree and laugh along if it weren't for the fact that: the price is high, there are shipping costs and we can't just drive 5 minutes to the store to return it.
