Main > Everything Else
Transfering data between different windows os's
Pages: << < (2/3) > >>
SithMaster:
my account had a password but is it only documents and settings?
how did you get around the password issue?
well i wanted to pull about 60gb worth of info -less actually becuase i only need the game save files not the entire games- but i was going to use a external hd connected through usb.  otherwise i could connect a third hd with a ide cable
ChadTower:
--- Quote from: SithMaster on November 09, 2006, 03:24:17 pm ---my account had a password but is it only documents and settings?
A drive password issue is different than an OS login.  So you're probably good.
--- Quote ---well i wanted to pull about 60gb worth of info -less actually becuase i only need the game save files not the entire games- but i was going to use a external hd connected through usb.  otherwise i could connect a third hd with a ide cable
If you want to pull 60g, you're going to need 65-70g of space on the drive to which you are installing XP and moving those files.
SithMaster:
if thats the case then i hope i can find a bigger hd otherwise i can try and move everything off my 160gb (maybe 70gb on it) and put it on a 250gb and then use the 160gb as the master.
ChadTower:
As the SithMaster.
SithMaster:
lol.
Go to full version
