May 08, 2024, 09:12:35 pm
This place is dead lately. Stingray scare everyone off?
First off, Hoopz is right.
Do other USB devices work properly on your pc? Is it USB 1.x or 2.0? Built in USB on your motherboard or an add in card? Do you have the latest updates for Windows 2000?A short term work around is to plug the I-Pac into the pc via PS/2. While not what you want, it at least allows you to make sure its functioning properly. Then you can try and trouble shoot the USB side.
Have you tried plugging in a plain old USB keyboard or USB mouse? Is this a fresh install of Windows 2000? Did you have any funky specialty keyboards or mice hooked up to it at any point?
Oh I think I get it now... Windows doesn't detect I-Pacs and Opti-Pacs as keyboards and mice. They're detected as HID devices. That's different.
No, it's not.
Quote from: mvolke1 on November 09, 2006, 02:56:56 pmNo, it's not. Unless there's something on that machine you can't stand to lose, I recommend wiping the hard drive and starting from scratch. That would absolutely be step #1 if I were in your shoes. (Of course, if you don't have the disk or key to do that, it could make things harder).Not only should it fix your encoder issues, it's bound to perform better with less junk on it.
The thing about the drivers, though, is Andy from Ultimarc says the Opti-Pac doesn't require drivers, so that confuses me.
Just a curiosity question more than anything. Why use Win2k? It was made to replace Win NT4 and I don't think it's really designed to be overly graphics friendly is it? Just curious.Encryptor
