Author Topic: monitor flipping and I-Pac 4 ???  (Read 892 times)
mvolke1
  • Last login:August 27, 2020, 09:48:24 am
    • My Pi-Powered Galaga-Thmed Bartop
« on: November 08, 2006, 04:47:58 pm »
My cocktail cab is built, and all the controls are wired up, though not working (my cpu doesn't like the I-Pac or Opti-Pac in the USB...a seperate issue).
My question is on the monitor installation. I have mine installed, centered well,  looks great, but I need to rotate the image so it's facing the side control panel. The image is facing the back of the machine (though installed properly).
I have Windows 2000, but I haven't figured out how to flip the image with the software. I also have the Wells Gardner U3100, and I don't know if there's a way to flip its image with the controls it has.
Another question...I'm using an I-Pac 4. I would like to have it be 4-player, but have the option to make the side control panels work for players 1 and 2 for horizontal games. Is there a way to do that?
Thanks for the help.
I'm with stupid.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: monitor flipping and I-Pac 4 ???
« Reply #1 on: November 09, 2006, 05:37:18 am »
If you have an ATI video card this should allow the rotation from the control panel software. If it does not, I might be able to supply a version of the control panel which does.
For the side panels, you could either connect them to the same inputs as the end panels (which does not really require and I-PAC 4 as the I-PAC 2 has enough inputs) or you could wire then up to the player 3 and 4 controls and re-program the I-PAC and/or the Mame controls menu to suit. If you reassigned using the Mame control menu this would allow max flexibility as you could do it on a "per game" basis.
Andy
loadman
  • Last login:August 17, 2020, 03:23:55 am
    • MaLa
« Reply #2 on: November 09, 2006, 07:12:34 pm »
If you wire them up seperatly you could take advantage of MaLa's controller detection if you so desire..
http://mala.arcadezentrum.com/controllerdetection.html
koolmoecraig
    • My Intervention
« Reply #3 on: November 09, 2006, 07:16:48 pm »
Wrong forum, sorry.
« Last Edit: November 10, 2006, 01:28:54 pm by koolmoecraig »
loadman
    • MaLa
« Reply #4 on: November 10, 2006, 12:00:41 am »
-Ignore this post  :-[
« Last Edit: November 10, 2006, 05:39:47 pm by loadman »
  • Last login:Today at 07:54:28 pm
« Reply #5 on: November 10, 2006, 11:11:59 am »
If you use -flipx and -flipy in mame you can get the image to display upside down.
