Main > Everything Else
Air compressor
somunny:
Yeah, I would think it would be somewhere closer to 100psi. Is there a regulator you can adjust? What make/model is it so I can take a look at it?
WunderCade:
If there is an unregulated hole or a break with air escaping, there shouldn't be. Compressors have release valves that will allow you to evacuate the pressurized air when your done, but it is regulated by a valve and air shouldn't be escaping during use.
A pic would help, is it a pancake style compressor? Does it say how many gallons on it?
ChadTower:
--- Quote from: somunny on September 13, 2008, 05:18:44 pm ---Yeah, I would think it would be somewhere closer to 100psi. Is there a regulator you can adjust? What make/model is it so I can take a look at it?
Yep, but even when all the way turned it only gets to 40psi or so. I'll get pics later on today if the rain lets up.
missioncontrol:
--- Quote from: WunderCade on September 13, 2008, 05:23:26 pm ---A pic would help, is it a pancake style compressor? Does it say how many gallons on it?
But I thought waffles were superior to pancakes
skippy:
--- Quote from: missioncontrol on September 16, 2008, 07:06:46 am ---
Only at Waffle House. If your at IHOP you have to go with the pancakes.
Navigation
[0] Message Index
[*] Previous page
Go to full version
