Main > Main Forum
Perfect 360 with Competition Shafts
blietzkreig:
Considering SlickStick http://www.slikstik.com/order.htm offer the 360's as a upgrade option, but in black only, I dont like my chances.
DeathMonk:
I bought the complete kit.. From my experience, the p360s come with a heavier spring than the rest of the joys already.
tyweed:
my perfect 360 is sticking bad its been one week. any idea why this could happen?
OSCAR:
The P360's used to be a switch replacement option, but now they are their own joystick, as you have already guessed.
These bases are not made by IL and will not accept a 10mm shaft (that means Super and Comp shafts are out). It seems Happ "Americanized" the P360 and designed it with a 3/8" (9.5mm) shaft. If you go with a P360, you are pretty much stuck with the stock shaft.
