Author Topic: Can I make 3 HD into 1 C: Drive?  (Read 2942 times)
daywane
  • Last login:Yesterday at 02:08:40 pm
  • GRRRR!
« on: November 06, 2006, 08:14:53 pm »
Hope that made since.
I would like to put in 3 hard drives into 1 PC
but as far as windows would know  it is 1 large hard drive.
3 seventy gig hard drives and have windoes see it as 1 hard drive at 210 gigs.
can this be done?
fatfingers
  • Last login:January 26, 2015, 10:15:43 am
  • Got UltraStiks?™
Re: Can I make 3 HD into 1 C: Drive?
« Reply #1 on: November 06, 2006, 10:29:13 pm »
Do I dare ask why?
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
daywane
  • GRRRR!
« Reply #2 on: November 06, 2006, 10:58:52 pm »
AtomicFe will not do sub folders
I want to finish up my console PC . Atomics plug n play folder can get  huge rather fast.
so I hope to use the Hard Drives I have here or I will have to buy 1 very large Hard Drive
NickG
  • Last login:September 26, 2022, 05:25:23 am
  • Dig.
    • My Projects Page
« Reply #3 on: November 06, 2006, 11:08:20 pm »
Yes. it is called spanning.  It will either be fun or impossible sepending on your version of windows.
Silver
  • Last login:February 17, 2024, 10:29:00 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #4 on: November 06, 2006, 11:12:35 pm »
EDIT: Sorry posted Out of Date info.
If you are using XP or 2000, then you can span and mount the 2 extra drives into a folder on your C drive.
The 3 drives need to be formatted as NTFS, then go to "Disk Managment", convert the 2 drives to Dynamic disks, then you can create a spanned drive across them, then you can mount it as a folder.
Alternatively (and more easily) you can mount Each extra drive as a folder.
« Last Edit: November 06, 2006, 11:18:48 pm by Silver »
headkaze
  • 0x2b|~0x2b?
« Reply #5 on: November 06, 2006, 11:41:37 pm »
You can use Hard Links so data on two HDD's will appear as though they are located on the one drive. Pretty easy to do.
daywane
  • GRRRR!
« Reply #6 on: November 07, 2006, 06:11:54 am »
thanks guys.
figured if I need it, some one else has to before me   :cheers:
