Author Topic: Can I use a Dream Arcade shaft and balltop in an Ultimarc 360 or Mag-Stik?  (Read 1957 times)
  • Last login:Today at 07:54:28 pm
I really want to order a Mag-Stik from Ultimarc because it is 4/8 way switchable from the top (and I really like my T-Stiks) but I want a pink balltop.  I am also considering a 360 joystick from Ultimarc because it seems to be an all-in-one solution but neither of them come in pink.  Dream Arcades sells a pink balltop (http://www.dreamarcades.com/partssticks/pinkbtop.shtml).  Could I remove the stick from 360 or Mag-Stik and use the pink balltop and shaft from the Dream Arcade one?
Any thoughts?
THANKS!!
« Last Edit: November 05, 2006, 01:41:56 pm by javeryh »
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: Can I use a Dream Arcade shaft and balltop in an Ultimarc 360 or Mag-Stik?
« Reply #1 on: November 06, 2006, 01:15:56 pm »
If the balltops have the standard 6mm thread (which they almost certainly do) then the options are:
UltraStik 360: It will fit on the ball-top version.
Mag-Stik Plus: If you order the add-on ball-top handles it will fit, but you would need to drop me an email so that we can send the shaft with the ball not fitted, otherwise you won't be able to swap it owing to being Locktite Threadlock'd on.
Andy
« Reply #2 on: November 08, 2006, 10:28:22 pm »
Thanks Andy.  So does the ball unscrew from the shaft or will I need to replace the entire shaft?  I think I'm going to try the 360 - I'll be ordering it soon!
Aurich
  • Last login:September 12, 2021, 01:34:32 am
« Reply #3 on: November 09, 2006, 12:03:19 am »
If you want a pink ball top for one of Andy's sticks then you can just pick up a Japanese one (either Sanwa or Seimitsu) they're a direct fit (IIRC Sanwa is what Andy stocks, though in limited colors, no pink). Check the sellers in the the trading forum, can't remember if ponyboy stocks them, but eBay will nab you a couple easy otherwise, pink is a popular color for those.
For the 360 you just swap the tops, the balls are threaded on.
destructor
« Reply #4 on: November 09, 2006, 02:46:32 am »
You are wrong. Sanwa sticks doesn't fit to T-Stik or Mag-Stik, these are IL products.
These will fit to J-Stik (Sanwa JLW) or U360 (Sanwa JLW base) only.
AndyWarne
    • Ultimarc
« Reply #5 on: November 09, 2006, 05:23:29 am »
The ball tops do fit the T-Stik and Mag-Stik but you need to order the replacement shafts which we supply. On the UltraStik you can just unscrew the ball but on the replacement shafts for the T-Stik and Mag-Stik you cannot, and would need to request that we send a shafy without the ball fitted.
Andy
destructor
« Reply #6 on: November 09, 2006, 06:38:27 am »
Yes Andy, you should sell Mag-Stiks and T-Stik with ball-tops handles where we can unscrew tops (ball or bat). And it should be default.
After some time ball on my T-Stik Plus have burst in place where ball is connected with shaft. I think that there is pressure between shaft, ball and material which connect ball with shaft.
Kowal must made new shafts for Mag/T-Stiks where we can use seimitsu bubble balls for example. :)
Aurich
« Reply #7 on: November 09, 2006, 12:18:19 pm »
IIRC the issue is that Andy "glues" the balls on so they don't come loose when you use the mechanical switching action of the stick, which makes sense.
« Reply #8 on: November 09, 2006, 04:45:42 pm »
Just so I'm sure, I don't need an ipac with the Ultimarc 360, right?  I'm planning on 3 action buttons and 4 admin buttons (maybe a 5th for power on and off but right now I'm planning to just wire straight to the computer).
Thanks!!
fatfingers
  • Last login:January 26, 2015, 10:15:43 am
  • Got UltraStiks?™
« Reply #9 on: November 09, 2006, 07:26:52 pm »
Thanks!!
I'm almost certain the ultrastiks can handle 7, maybe even eight buttons.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #10 on: November 09, 2006, 09:22:40 pm »
Correct.  The Ultimarc 360 comes with its own USB interface.
Thanks!!
The Ultimarc 360 can have up to 8 individual buttons hooked up to it.  The PC power button should not be hooked to the Ultimarc 360.
destructor
« Reply #11 on: November 10, 2006, 02:37:21 am »
It makes sense otherwise, but this solution (glue) isn't good.
AndyWarne
    • Ultimarc
« Reply #12 on: November 11, 2006, 02:51:07 pm »
Des, can you suggest a better method? I can't think of one. We use Locktite Threadlock actually. On the Mag-Stik, because it must be able to be turned to allow 4-8 way switching from the top, the ball would simply unscrew if not locked on somehow.
Andy
destructor
« Reply #13 on: November 12, 2006, 03:36:02 am »
Andy
I think about it still. If I found something better I will inform you Andy.
Switching to right side isn't problem because metric screw is right (clock). Problem is with switch to left side only.
PS. In free time I show photo how my T-Stik ball is damaged.
