Author Topic: MAMEWah 1.62b10 and mame v.108  (Read 1153 times)
toasty
  • Last login:October 10, 2019, 11:48:47 am
  • Purveyor of Fine Latex Products
« on: November 01, 2006, 01:33:55 am »
Having some issues running mame v.108 from Mamewah -- it will start to launch a game, the dosbox will flash, and then it will go back to the game selection screen.
Here's my mamewah log:
11/1/2006 12:26:31 AM MAMEWAH v1.62 launched
11/1/2006 12:26:31 AM Cursor scheme: Windows Default, Arrow: (None), Wait: (None), AppStarting: (None)
11/1/2006 12:26:31 AM Desktop colour: 0
11/1/2006 12:26:31 AM Wallpaper filename: C:\Documents and Settings\Jamie\Application Data\Mozilla\Firefox\Desktop Background.bmp
11/1/2006 12:26:31 AM Display mode: 1024x768 @ 75Hz, 32 bit colour
11/1/2006 12:26:31 AM Decimal symbol: '.'
11/1/2006 12:26:31 AM Games list read: mame-0.lst
11/1/2006 12:26:33 AM Mode 800 x 600 @ 60Hz, 32bit colour selected after 2 attempt(s) at 1/2 second intervals.
11/1/2006 12:26:33 AM Layout selected: F:\mamewah_v162b10\config\mame\cpv\layout.lay
11/1/2006 12:26:34 AM No. joystick devices attached: 0
11/1/2006 12:26:34 AM Ctrlr file selected: F:\mamewah_v162b10\config\mamewah.cfg
11/1/2006 12:26:34 AM Keyboard enabled
11/1/2006 12:26:38 AM Current drive/directory selected: F:\mame
11/1/2006 12:26:38 AM Commandline run: C:\WINDOWS\system32\cmd.exe /c F:\mame\mame.exe digdug -verifyroms > F:\MAMEWA~1\files\verify {flags=81}
11/1/2006 12:26:38 AM Application quit: C:\WINDOWS\system32\cmd.exe /c F:\mame\mame.exe digdug -verifyroms > F:\MAMEWA~1\files\verify
11/1/2006 12:26:38 AM Commandline run: F:\mame\mame.exe "F:\mame\roms\digdug.zip"  -r 800x600 {flags=204}
11/1/2006 12:26:38 AM Application quit: F:\mame\mame.exe "F:\mame\roms\digdug.zip"  -r 800x600
11/1/2006 12:26:39 AM Mode 800 x 600 @ 60Hz, 32bit colour selected after 2 attempt(s) at 1/2 second intervals.
11/1/2006 12:26:43 AM Mode 1024 x 768 @ 75Hz, 32bit colour selected after 1 attempt(s) at 1/2 second intervals.
11/1/2006 12:26:44 AM MAMEWAH quit
and here's the ini I'm using:
### mame.ini (mamewah v1.62) ###
emulator_title                            Arcade
### List Generation Settings ###
rom_path                                  F:\mame\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file                           F:\mame\catver.ini
list_generation_method                    rom_folder_vs_listxml
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      F:\mame\mame.exe "[rompath]\[name].[romext]" {autodosbox}{nosafelaunch} -r 800x600
post_emulator_app_commandlines
general_app_commandlines                  F:\cpvw\cpvw.exe -r=[name] -c=[cloneof];f:\histview\histview.exe -r=[name]
### Artwork Settings ###
artwork_image_paths                       F:\mame\snap;f:\mame\marquees;f:\mame\control panels;f:\mame\titles;f:\mame\flyers
movie_preview_path                        F:\mame\videos
movie_artwork_no                          1
enable_fuzzy_search                       0
### Screen-Saver Settings ###
enable_music_in_screensaver               0
select_random_game                        0
saver_type                                saver_commandline
movie_path
movie_fullscreen                          1
quit_delay                                30
saver_commandline                         F:\mamewah\screensaver\ms_pacman.scr /s
### Additional Settings ###
music_path
lcd_display_file_path
### Settings used by MAMEWAH ###
current_list                              0
anyone have any thoughts?  I know I've had this happen before and it was an easy fix, but I'm just missing it for some reason.
Thanks much!
toasty
Re: MAMEWah 1.62b10 and mame v.108
« Reply #1 on: November 01, 2006, 01:35:42 am »
Oh, and for what it's worth, the romset I'm using is for .105, and I'm just recently upgrading MAME to .108. That's not the problem, is it?
trcroyle
  • Last login:December 05, 2007, 10:32:05 am
« Reply #2 on: November 08, 2006, 01:15:00 pm »
Switch {nosafelaunch} to {safelaunch}
toasty
« Reply #3 on: November 11, 2006, 12:49:42 am »
thanks, but that didn't fix it.  Anyone have any other thoughts?  I'm at my wit's end...
MKChamp
  • Last login:February 07, 2024, 02:45:53 pm
  • Stil around.
« Reply #4 on: November 11, 2006, 01:34:14 am »
That could easily be caused by a bad game rom...MAME won't load it...goes back to MAMEWAH. Try it with a different game/games...
If SOME of them load, then you know it's your rom set...
toasty
« Reply #5 on: November 11, 2006, 11:29:07 am »
I've tried dozens of roms, still no luck.  The weird thing is that all my other platforms launch from Mamewah just fine.  I've now tried upgrading mamewah to 1.62b12, and still no luck.  I'm utterly puzzled.
