Main > Main Forum
NooB! Looking For A MAME Cabinet, Need Buying Advice ASAP!
Pages: << < (2/2)
Auntie MAME:
It depends on how deep your pockets are and how much work you want to do.  The easiest thing is to get an empty cab (cheap) and put a PC monitor in it.
If you have more time and money get a new or used arcade monitor.  You can't beat the look of a real arcade monitor.  The configuration is more complex, but arcadeVGA for Ultimarc has made it a bit easier.
There is no quick fix.  You need to spend time doing some R&D.
Nailz:
Don't buy the Donkey Kong if you are just going to sell off the components.....
Buy an empty shell of a cab and go from there.  Finding a monitor and all that is fairly easy.  You could also just build a cabinet yourself, there are a TON of plans out there for just that purpose.
Pages: << < (2/2)
Go to full version
