Main > Everything Else
Post your personal websites/creations
quarterback:
--- Quote from: shmokes on November 21, 2006, 11:20:19 am ---That would be handy for so many different projects. I hope the thread turns up.
I'm not sure which one Shardian is referring to, but I've seen a couple options posted on BYOAC. The two that come to mind are the ones from Markertek and than smaller ones from datapro
The markertek option would be 'cleaner' because you don't have to dremel out a rectangular hole whose edges will be visible. Unfortunately, the markertek one is also much larger and I don't know if your frame can take it.
datapro
Markertek
shmokes:
wow . . . those look incredibly easy to install. Thanks!
quarterback:
--- Quote from: shmokes on November 21, 2006, 12:39:05 pm ---wow . . . those look incredibly easy to install. Thanks!
No prob. If you end up using one of those, show us some pics. I have at least one laptop lying around doing nothing and your project has got me thinking again about making one of these.
EDIT: Those Marketek ones come in black as well. There are 2 brands that have similar items, one is Switchcraft and the other is Neutrik. One brand is much less expensive than the other if I remember correctly.
I hope you go with the Markertek item. The datapro seems overpriced IMO. Plus, I want to see if the Markertek ones fit into your frame. :)
shmokes:
I didn't even click on the datapro ones because they're so ugly compared to the Markertek ones. They're already ordered. I'm using the inexpensive one. They're only like $4.80 apiece or something so I ordered two cos I know I'll want another one in the future (if I wasn't so poor right now I'd have ordered five.
This is really exciting. It's going to add quite a lot to the finished product. Thanks again for the heads up. I'll definitely add a pic when it's in.
tophatne1:
deleted
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
