Main > Everything Else
Why is it called 110volt and 220volt? Sheesh...
Pages: << < (6/9) > >>
rdagger:
--- Quote from: MYX on October 26, 2006, 04:25:53 pm ---Yeah, 110, 111, whatever it takes.
"220, 221, whatever it takes..."
Stingray:
--- Quote from: ChadTower on October 25, 2006, 08:04:14 am ---BTW, we have pole mounted transformers here.  They are normal.
Still pretty common here too.
-S
shardian:
If I remember correctly from my Ciruits II days, power lines carry 14,000 volts.
ChadTower:
In a situation where the load is balanced properly, the equipment is completely functional, and nothing is jury rigged to compensate for overbuilding or missing lines/equipment that has failed and not been replaced.
And there aren't many lines like that where I live.  The structure is just too damn old.
Ed_McCarron:
--- Quote from: shardian on October 27, 2006, 11:27:14 am ---If I remember correctly from my Ciruits II days, power lines carry 14,000 volts.
Depends.
Typical for our area, the top-most lines on the poles carry 13.2kv.
Chad's right, if depressing.  Get tangled up in that and it'll burn you to a cinder after it stops your
Go to full version
