Author Topic: How do you cut a Happ plastic monitor bezel?  (Read 1248 times)
arzoo
  • Last login:April 14, 2024, 11:15:11 am
  • Robots WILL kill you.
    • LEDBlinky
« on: October 23, 2006, 09:00:46 am »
I purchased a 27" plastic bezel. Any suggestions on how to cut it down to size for my cab?
« Last Edit: October 23, 2006, 09:52:08 am by arzoo »
Robots will kill you.
Arcade Addiction
whammoed
  • Last login:Yesterday at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
Re: How do you cut a Happ plastic monitor bezel?
« Reply #1 on: October 23, 2006, 09:42:06 am »
score with utility knife along a straight edge
bend back an forth along the line and it will break along the line
arzoo
    • LEDBlinky
« Reply #2 on: October 23, 2006, 09:52:58 am »
That's what I was thinking. Thanks!
Arcade Addiction
Ken Layton
  • Guru
  • Technician
« Reply #3 on: October 23, 2006, 10:39:05 am »
Tin snips.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #4 on: October 23, 2006, 12:19:30 pm »
Tin snips.
Nahhhh!! CNC Laser Cutter.....  You should be able to pick one up for around $20,000 from all good tool suppliers.  :cheers:
Better still... take it over to NASA JPL and have them mount it in a heat proof frame, with the bits you dont want sticking out, then have them stick it under the next shuttle they launch.... this is rocket science this is!
Best Regards,
Julian (Fozzy The Bear)
« Last Edit: October 23, 2006, 12:25:45 pm by Fozzy The Bear »
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #5 on: October 28, 2006, 02:52:12 am »
Razor with straight edge worked great for me... I also used a fine grit sand paper along the edge to "perfect the fit"
My old user name was marlborroman13, but I kicked the habit many years ago!
