Main > Main Forum
Control Panel Database: Post a picture of your Control Panel!
Pages: << < (166/209) > >>
PL1:
--- Quote from: steved61 on August 22, 2013, 11:53:14 am ---But why would you use these on a control panel, instead of direct wiring?
IIRC one guy used them for temporary single color LED button wiring while he figured out (and gathered the funds for) an RGB LED button setup.
They are an easy way to disconnect/replace RGB LEDs that come with wire leads instead of running new wires all the way to the controller and messing up the existing wire bundles.
Also the euro terminals work better than crimps (un-soldered) if you need to splice solid core wiring.
Garza:
Good thought on the RGB's didnt think of that. I am redoing my cp right now and will use the bridges. However was looking at yours, not showing in detail of the hook up. Do you just daisy chain all your RGB's and then at the end you just have one wire for each RGB power going in? Thats what I got out of it. Can you let me know? Thanks  :banghead:
PL1:
Here is a recent post on that topic with an excellent diagram.
[/thread derail]
JustAskJack:
shponglefan:
^ Love the concept and way you made the borders for the various controls (esp. the trackball).  But why does the textured part of the art stop so premature of the bottom edge of the panel?
Go to full version
