Main > Main Forum
Control Panel Database: Post a picture of your Control Panel!
Darth Nuno:
Here's my first custom panel, done three years ago.
Starting point :
...then...
The result :
All the construction right here
jacenwon:
--- Quote from: AtomSmasher on October 23, 2006, 02:11:28 pm ---Best pic of my CP is from before I put it on the cab:
props! i had to - it doesn't get much sexier that that ^^^
Teknique:
Here is my (3rd) CP. It has 2x 49ways with aluminum bat handles, 2x LS-30s, arkanoid spinner and happs trackball. It also sports built-in cup holders. No artwork yet (Im having trouble finding someone willing to let me pay them to do it) but eventually will have some type of ninja theme. If you can't make out the marquee, the name of the arcade is 'Baby Shoguns'. The CP is loosely based on a Slik Stik Quad modified to work with a UA2 cab.
Tek
XyloSesame:
--- Quote from: Teknique on December 20, 2007, 09:06:39 am ---Here is my (3rd) CP. It has 2x 49ways with aluminum bat handles, 2x LS-30s, arkanoid spinner and happs trackball. It also sports built-in cup holders. No artwork yet (Im having trouble finding someone willing to let me pay them to do it) but eventually will have some type of ninja theme. If you can't make out the marquee, the name of the arcade is 'Baby Shoguns'. The CP is loosely based on a Slik Stik Quad modified to work with a UA2 cab.
Tek
I'm not typically a fan of the larger panels, but Tek, you did it right... The panel wrapping around the cab is a great touch and ties it all together; good job!
rdenis:
Here is my first CP from my newly completed first project. It is 34 x 18 and made from 3/4" maple ply. The CPO is custom designed and was printed my Mame Marquees. Two player panel with 7 buttons per player, U-360 joysticks, TurboTwist 2 Spinner and Betson Imperial 3" trackball (RGB). Pinball buttons are located on each side of the control panel base. Buttons to the right of spinner are left and right mouse controls. The control panel top has two hidden hinges in the front so it opens away from the monitor glass for maintenance and storage of my LCD TopGun.
Lighting is controlled by LED Wiz driving 8 RGB buttons, 1 RGB trackball, and 5 single LEDs.
Unlit:
Lit:
