Main > Main Forum
Control Panel Database: Post a picture of your Control Panel!
Pages: << < (37/209) > >>
Malenko:
--- Quote from: urbecrisch on September 04, 2007, 12:12:48 pm ---Malenko, why did you get rid of the LED'S?
http://forum.arcadecontrols.com/index.php?topic=69808.0
pod:
One more to the list... I built this cabinet about 4 years ago and just recently decided to upgrade it to translucent Happ buttons driven by an LED wiz. The back panel buttons have the GGG RGB board installed and the rest I just drilled a hole and put in single color leds. Happ trackball is also now lit by 3 bright whites in a home made bracket...
sdrob04:
Hard to believe it's been a year since we "finished" our first cabinet (quotes added for the amusement of anyone who's built one  :) ), and alas, still no website.  Here goes with a truncated summary...
Mostly a LuSiD-based design, with the following controls - Top row:  Oscar Push-Pull spinner, Wico 4-way joystick, Happ Heavy Duty joystick.  Bottom row:  Wico 8-way joysticks, translucent leaf buttons, Happ Hi-ball 3" trackball.  Extra function/admin buttons on sides of box.
Details of note:  All controls designed to be installed/removed/serviced from the bottom so as to not disrupt the artwork.  Dust washers float underneath the artwork.  Button layout is the result of a painstaking analysis of the top 100 classic games and works quite well, believe it or not.  We're still wiring up the button LEDs and working to optimize the ease-of-use.  Will it ever be DONE done?
DaOld Man:
looks good.. I like the twilight zone overlay..
Malenko:
redid the control panel AGAIN:
Go to full version
