Main > Main Forum
Control Panel Database: Post a picture of your Control Panel!
Pages: << < (29/209) > >>
Spyridon:
Nice, love the Crisis theme!
GameOver:
Love your CP DrumAnBass!  Looks like fun!  Here's mine, soon to be redone to straighten out the joysticks, and will use Rally X CPO
gse123:
This is my first ever attempt to build an arcade stick after only getting into the whole MAME thing about 6 months ago.  Unfortunately as I do not have space for a full size cabinet I have made a desktop stick.
The top panel is made from 4mm thick steel, the buttons and stick are Sanwa. The buttons have been custom painted a metallic blue and red (probably a step too far, but I do love to mess about with things!
Base box is just MDF that I have veneered... unfortunately it chipped off at the back corners when I was trimming it off, so it isn't as neat as i'd have liked.
It has taken me a long time and many parts messed up to make this... but time hopefully well spent!   :)
Petey Boy:
My first message on this board, although I've been reading for years and gathering help from all your work...thanks for the inspiration.
Here's mine...with a Defender theme - although I have no Defender button placements - I played mostly Atari 2600 which was way simpler...
Three Ms Pacman Reunions (a mistake I my part, maybe, thinking they had a different feel than the Happs Super 8-ways) I converted the base of two with a round 8-way plate.
Happs Blue Glow Trackball - still gotta wire the 'glow' up, but I'm afraid I'll burn out my power supply with the coin door lights already sucking out juice...
Turbo Twist Spinner- Nice!
Two Act Labs Arcade Guns - I drilled out two buttons so wiring can enter smoothly into the cabinet...the holsters are Home Depot "U" bolts that need to be painted black but I'm afraid they are too smooth and end up looking like crap.
Special thanks to Kneivel (spelling?) Wow!
Petey Boy
Petey Boy:
I forgot to mention the GroovyGameGear Ball Tops 1.5" balls  :cheers: for biggier hands that were machined to fit under my control panel and regrooved to be at the right height for a Ms Pac Man Reunion (or pretty close to it)
Go to full version
