Front End Support > MaLa Frontend
UltraStik Mapper plugin for MaLa Version 1.3.00 now released (1/30/09)
<< < (15/47) > >>
loadman:
--- Quote from: fatfingers on December 29, 2006, 07:03:06 pm ---I first tried it with ultramap in its own directory and I could not get it to work.  I only tried for a little bit.  I couldn't see any problem with have the ultramap software in the mala folder so I did this instead.
Popcorrin:  Any chance you are using a shortcut to start MaLa?
[/quote]
If so it could be the same issue I had with the 'speech' plug-in. You can either add the path into the 'start-in' section of your short-cut or fat-fingers can re-code to set the working directory.
See this thread:
http://forum.arcadecontrols.com/index.php?topic=59589.msg593164#msg593164
fatfingers:
I would like to extend my thanks to Ninten-doh for his help in debugging his issues today.  He spent a ton of his "free" time working with me.  Unfortunately I still have not tracked his issue down, but am hopeful we are getting close.
Thanks Ninten-doh!  :cheers:  :cheers:  :cheers:  :notworthy:  :notworthy:  :notworthy:
Ninten-doh:
FF, you're totally welcome!  It's the least I can do to "give back" to you and the other programmers who come up with these great free programs and plug-ins.   :applaud: :applaud: :applaud:
Good news is the latest beta you sent me is just about perfect!  A minor(?) desktop flicker when exiting games is the only remaining issue I seem to have.
Popcorrin:
--- Quote from: Popcorrin on December 28, 2006, 07:36:14 pm ---
--- Quote from: fatfingers on December 28, 2006, 11:59:43 am ---
Popcorrin: Did you try the plugin with UltraMap in its own directory first or just go directly to installing in the same directory?
Thanks guys!
I am not using a shortcut to start MaLa.
fatfingers:
--- Quote from: Popcorrin on December 30, 2006, 09:57:51 am ---
 :timebomb:
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
