Main > Main Forum
ActLabs - MAME - Readl Arcade RGB Monitor? Only works outside of MAME
StephenH:
It could be that your monitor is 15Khz and the guns were designed for true VGA or SVGA (31Khz or higher).
radiator:
--- Quote from: Anonymously on March 30, 2003, 12:24:56 am ---
--- Quote from: tom61 on March 28, 2003, 04:31:35 pm ---
--- Quote ---but sadly I don't like the blurry look on the cabinet, almost defeats the purpose.
Change the effect setting to 'sharp', doesn't look as blurry.
Hmmn tom61 How do you do that with Hardware streaching?
load up yer mame.ini file and look for the line 'effect none' (may be set to something else if you've enabled scanlines or something) - simply change it to sharp to get a better image
:P
Chris:
I thought all the effects were disabled when hardware stretch was active... ???
