Main > Main Forum
IPac - SHIFTed keys via toggle switch?
Tiger-Heli:
--- Quote from: Brad Lee on March 24, 2003, 10:57:40 am ---When you say the shifted keys operate on key release, if I hold a button down it'd just send once, when i let go ? If thats the case that'd definitely be not good for shooters that have repeat fire, or a run button. If I read that correctly.
That's how I read it from the Ultimarc text. You could try it out with your I-PAC/2 yourself if you wanted to verify.
Brad Lee:
I'll give it a shot cuz I'm re-wiring my entire CP anyway. Like most of the rest of the questions, the best way to find out is to try it
From re reading the ultimarc page linked above it seems that the shift key itself works on release to avoid unwanted keys, but that when shift is held down, your normal keys fire as expected
AndyWarne:
Yes, only the shift key itself works on release, the others are normal when the shift key is held down.
There is a new version of the WinIPAC program on the way which gets rid of the "OK" box after a batch mode program and corrects a couple of other issues. I will be testing it tomorrow and then upload it.
Andy
Brad Lee:
I did some testing of multiple configs, notwith a toggle but a heavy book keeping the shift button pushed:) and it worked flawlessly
I also did some playing with batch files and that works pretty good too
and cool about the winipac prog, I'll keep an eye out for it
_Iz-:
Andy - I don't seem to be able to find any version numbers or date posted on the WinIpac download page for the utility. Makes it difficult to see if you have the current version without downloading it again.
