Main > Main Forum
My 1st Control Panel Almost Complete!
bsoder52:
Thanks for the aditional feedback. With these interfaces (Ipac & Keywiz): do they have hookups for a keyboard to override the button configuration if needed?
BobA:
I am not sure if everyone read the info in my other post correctly. I said that if you wire the 4 way and 8 way together for the first player you could use the IPAC-2. Which is what everyone said again for some reason. Maybe they were trying to point it out again as you seemed to choose the IPAC-4.
Use either IPAC as it has a true kb passthru. The keywiz has only a switchable kb port AFAIK.
BobA
bsoder52:
Thanks again! Sounds like the Ipac2 is the way to go! I can't wait to get the system finished off! Man, it takes alot more time and effort for one of these projects. :)
But extrememly addicting!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
After my Mame Cab (God willing it will get finished and will work) will be a laser disk type standup, then I'm thinking a trackball stand-up. That should keep me busy and broke for at least a year......:)
