Main > Main Forum
Neat wiring job question
arzoo:
Another (obvious) method for neat wiring is to use different color wire. Although it doesn't seem to have helped in the cp above! :dizzy:
ArcadEd:
--- Quote from: Not Lewis Black on October 10, 2006, 03:39:42 pm ---Also these can be found in the aisle by nylon ties.
These are the ones I like, the mounting tape ones, not the nail in.
johnm160:
ArcadeEd,
What type of wire is that your using? It looks like the 25 pair phone lines.
ArcadEd:
That's actually a Happ Jamma Harness.
For arcade box builds I just use 22gauge stranded wire. Green, Red and blue. Green for ground, red and blue for players 1 and 2.
I bundle pretty close to the same way though. :)
johnm160:
--- Quote from: ArcadEd on October 13, 2006, 09:49:26 pm ---That's actually a Happ Jamma Harness.
I see, I thought that was too many colors to be the run of the mill home center stuff... ;D
