Main > Main Forum
A ROM is a ROM is a ROM or is it?
ahofle:
--- Quote ---If a Rom was listed as competed on the first version of MAME than it would work with any modern emulator now right?
No it could still be found later to have been incorrectly dumped (or #3 in Mr. Do's example). It's probably simplest to just accept that no ROM set is guaranteed to never need to be changed again.
Stingray:
--- Quote from: ahofle on October 09, 2006, 02:44:53 pm ---It's probably simplest to just accept that no ROM set is guaranteed to never need to be changed again.
It's simplest to find a version you like and just stick with it. Pretty much everything I want has been working perfectly for years.
-S
rackoon:
Thanks guys, I kind of get it now. I think I miss used the word ROM when I should have said ZIP file. That just goes to show you that I don't know squat but I'm trying to learn the computer side of MAME because my cab is close to being finished. I just need about $400.00 more bucks (drop in the bucket) and a crap load of time. I do most of my work in the winter when it snows. :blah:
Tommy Boy:
I'm embarassed to say that I've been lurking around here for 5 years or more and don't know this: Who keeps the "official" set of MAME ROMs? Who is the "gold standard"? I'm pretty sure it isn't a member of MAMEdev, correct? I know that Guru does much of the dumping is he also the main archivist?
Dav:
There isn't necessarily a reference set. The hashes are the reference.
