Author Topic: Coin Door problems-I need help- Tokens not registering EVERY time ??  (Read 1439 times)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
I use Happ Quarter/Token Mechs and when I put a token in sometimes a credit registers.  Sometimes the switch is not fully activated.
Out of frustration, sometimes I just push 3-4 tokens ina slot in rapid succession to get it to register one credit (one press of the "5" key)
Some games even give me a "coin error" message in mame?  huh?
I've figured out that it seems like the little wire arm that activates the switch is not swinging down fully under the weight of the tokens.
Is there some adjustment I can make so that the switch gets hit easily and consistently?
thanks
-tim
SirPeale
  • Green Mountain Man
Re: Coin Door problems-I need help- Tokens not registering EVERY time ??
« Reply #1 on: October 07, 2006, 02:32:38 pm »
Could be a bad switch.  Or a sticking switch.
Easy way to tell would be to put a game into switch test and start running tokens thru it.  If it gets stuck take a look - perhaps the wire actuator is sticking to the sides.  Just adjust the wire if that happens so it doesn't rub.
If it's not that...well, keep looking.
Gambit
  • Last login:November 16, 2006, 09:40:19 am
    • The BlueSparks Network
« Reply #2 on: October 07, 2006, 06:38:47 pm »
Mine has a dip switch that sets how long of a signal it sends.  5 ms, to quick and will cause problems like you describe. 150 ms, just right.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #3 on: October 07, 2006, 06:56:18 pm »
Timoe,
It sounds like you have the coin switch wired incorrectly.  This would cause coin errors in some games. Check that you have the wires going to the NO (normally open) and COM (common) tabs of the switch.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #4 on: October 07, 2006, 07:38:38 pm »
just to clarify. If I move the little trip wire on the coin mech with my finger it hits the switch perfectly.
It's like the lever is not being pulled down far enough when the token rolls over it.
I will take pictures and perform additional tests.  I will post results here.
unclet
« Reply #5 on: October 07, 2006, 07:49:19 pm »
I have similiar problems with microswitches used on my Skeeball machine.   Sometimes the microswitch does not register and sometimes it registers twice in quick succession ... causing the score to register as double than what it should be.    If I move the metal arm to activate the switch by hand then it works fine, however, when a ball hits the metal arm of the switch is does not work fine.
Anyway, when I replaced the microswtich it works great.... maybe they is the easiest thing for you to do ...
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #6 on: October 07, 2006, 08:18:07 pm »
Here is a picture to show the wiring and a picture to show the metal arm I am talking about.
Should I bend it or something?
Id hate to place an order with Happ just for that switch.
JustMichael
« Reply #7 on: October 07, 2006, 09:01:18 pm »
Your coin switches do appear to be wired incorrectly.  Please move the wires from 1 of the 2 metal tabs that are sticking   up (they are the tabs next to each other on the upper side of the switch) to the other metal tab that is sticking up.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #8 on: October 07, 2006, 09:49:23 pm »
I was so sure I was right.
I was wrong.
Thank you JustMichael
