Main > Main Forum
looking for golden tee cp art
Pages: << < (2/3) > >>
kspiff:
That's a no go on the decals.. they're under plexi with hex security bolts, too, so I don't think I could even get a good scan (if I even had a handheld scanner).
I would just buy a set.. depending on how much they cost..
Ghoul:
Well if you want to go all the way happs sells a golden tee fore control panel, assembled with decals, trackball, and all buttons. It's the newer CP design, not the older one with grass and stuff.
CP is 180 bucks. To break down the cost of building your own, figure the trackball is 90 new, although it's on sale right now, buttons will be about 9 bucks, printout of the art will cost you some money and not be as good, and you don't have to spend time building it if you just buy it outright. Also you don't have to worry about it being poorly built or making mistakes on it if you are not good at that sort of thing. It's also going to be friggin sturdy because it's designed to be thrown in an arcade with a bunch of drunks beating on it.
So I guess if you want to take the plunge and this is strictly a golden tee CP I'd say just buy the happs one and save yourself the headaches. It's the most authentic and probably highest quality that you are going to get unless you are good with tools.
rampy:
Didn't smack for his mega heiney cabinet (or whatever)make a scan of the "instructions" / mousepad thingie that came with the PC version of Golden tee?
I know I've downloaded at least the trackball arrows thingie before and stashed it somewhere for later use...
*shrug* if I find a link i'll forward it... EDIT <<<<>>>>>Blammmmo!  probably not quite what you wanted but I think I need to add it to mine somehow...
rampy
Smack:
You beat me to posting the link. ;D
That was a pic I got off the net and cleaned up the text so it was readable. The manner in which you have to do the shots takes 3 trackball movements as opposed to 2 like the arcade version.
Golden Tee baby, Golden Tee... :)
smack
Chris:
Here's the link to the one I did for my cab:
http://mywebpages.comcast.net/celamantia/mamecab/images/bezel_art_bottom_right.png
--Chris
Go to full version
