Software Support > DOS/WinCab
When I Start Wincab I get this
billblumjr:
Ok it started up ok that time.. it said I had a fatal error.. no songs in pathline.. so I am gonna redo that and see what happens.. otherwise.. it works
Chris:
Everyone sees that one the first time... I really need to make it prompt for a path rather than error out.
billblumjr:
No prob.. put the path in.. and now it works.. thanks
blicky:
Hi just found this old post and I have a similar problem (never really worried too much because Doscab works fine in a full screen dos box anyway). The sound card works in windows and in dos but Wincab throws almost the same error.
0:00:00.00-LVL1-DEBUGLOG_INIT: DWJukebox for Windows Ver. 3.1.5 (Jan 20 2008 build) Started
0:00:00.00-LVL5-DEBUGLOG_INIT: Debug log detail level: 5
0:00:00.00-LVL5-DEBUGLOG_INIT: *****************************************************
0:00:00.00-LVL5-DEBUGLOG_INIT: SYSTEM INFORMATION:
0:00:00.00-LVL5-DEBUGLOG_INIT: OS version: 4.10
0:00:00.00-LVL5-DEBUGLOG_INIT: Library version: Allegro 4.2.0, MSVC
0:00:00.00-LVL5-DEBUGLOG_INIT: CPU Vendor: GenuineIntel
0:00:00.00-LVL5-DEBUGLOG_INIT: MAX_PATH: 260
0:00:00.00-LVL1-MAIN: Using initialization file: jukebox.ini
0:00:00.00-LVL2-MAIN: Initializing sound driver...
0:00:00.00-LVL0-MAIN: *** Error initializing sound driver.
0:00:00.00-LVL0-MAIN: Error message: Failed to init digital sound driver
Chris:
I wonder if something else is using the driver at the time the jukebox is starting up. Do you have more than one sound card in your machine?
Navigation
[0] Message Index
[*] Previous page
Go to full version
