Main > Software Forum
Boot CD installs DOS, Vantage, Raine, MAME (1 of 7 versions) and Game Launcher
<< < (39/64) > >>
HaRuMaN:
--- Quote from: spystyle on April 03, 2008, 08:40:41 am ---
--- Quote from: ringram on April 03, 2008, 08:31:31 am ---How do you support networking in DOS? I've tried to set this up before, but had very little luck.
I don't know how... but why would you need networking on an arcade PC?
Cheers,
Craig
If you had networking, you could add/modify files from a desktop.
spystyle:
You might as well use an optimized Win98 or an Nlite'd XP if you want to perform high tech stuff like that. DOS is a very basic, simple OS.
Cheers,
Craig
ringram:
I was wanting to share the drive and work on it from another computer. I know Microsoft had dos network support. I just haven't had much luck with it. For now, all I do is offer a menu on bootup to go into arcadeos or win98. So, it's a work-around, but, it would be nice if I could just share out the drive.
tikbalang:
there is a DOS ftp server called EZNOS:
http://www.dossolutions.pwp.blueyonder.co.uk/eznos.htm
you can add the server as menu option in config.sys.
Mamezilla:
Craig,
You did a hell of a good job with that ISO and I want to thank you for it.
However, I'm having problems  with Game Launcher that doesn't want to load at all.  When the commandline loading it arrives, the screen goes black and the computer freezes.  It's an AMD K6-2 500MHz with 256 megs of ram and and ATI Mach 64 video card.  I even was not able to get to the splash screen of GL, the screen goes black and the computer freezes before.
I've tried tried different install options with different emulators and different version of them, tried preventing SDD to load by putting a "rem" at the beginning of the command line in autoexec.bat, etc...  Everything I try gives me the same problem.
The sound card is a SB 16 PnP and all settings are OK, it works.
Any suggestions ?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
