Main > Main Forum
Super Joysticks..non-Happ?
Q*Bert_OP:
thos look like Betson's form of the super joystick...called the superior joy? by them...
Lewis Black:
The plastic handles are different from Happ supers.
kowal:
--- Quote from: AE35 on October 03, 2006, 01:12:29 pm ---
I can't read the polish on your site, are there any other reviews?
Thanks,
Nicholas
it be visible photos and numbers
mode - 8way
rotation - circle
throw - 15mm |12 degrees
engage - 11mm | 8,5 degres
range of diagonals 10 degres | hit 30%
spring 0,43kG | 4,21N
ahofle:
--- Quote from: leapinlew on October 03, 2006, 01:14:52 pm ---This cant be true. I had a magstik and I have supers now. Nothing has a shorter throw than a magstik.
Corrected my post. :banghead:
Grasshopper:
I've got a couple of these which I bought off another board member a few years ago. I've never actually used them because they were fairly beaten up and one of them was missing a spacer (the seller didn't tell me about this >:() however, I can comment on their appearance and build.
They feel very solid, almost as well made as the Happ/IL Supers on which they're clearly based. Definitely not junk. One thing I like about them is that the visible section of the shaft below the bat handle is solid metal whereas on the Happ supers this section of the shaft is covered by a plastic sleeve. This is obviously only a cosmetic difference but it makes the joysticks look a little classier IMHO.
The joysticks are height adjustable and both heights are slightly higher than the Happ equivalent. So they're easily fitted to a wood panel. The downside is that the extra height makes the joystick's throw a little longer than the Super's, and the Super's throw is already too long IMHO.
I can confirm the microswitches are crap but they're easily replaced.
I believe they're manufactured by SunBetty.
http://www.sunbetty.com.tw/products_disp.asp?cat=2
