Main > Everything Else
PicooZ indoor Mini-Heli
Texasmame:
--- Quote from: MikeDeuce on October 26, 2006, 12:35:01 am ---Try tweaking the rear blade thing per the manual... where it says if it's moving backwards, twist the rear thingamajigger this way or that way... that helped quite a bit. Otherwise it was just hovering for me... Also try holding it with the nose pointed slightly downward with the rotors going full blast, then letting it go. Sure is quick when you do that!
2 rear rotors down for me. One cracked and one isn't tight on the shaft anymore... should be able to salvage both though. All hardwood floors, no soft furniture, and mr. clumbsy at the controls :dizzy:
Added the pushpin to the nose, now it's flying forwards pretty good. Still gotta mess with the trim a bit. . .
No breaking so far. The thing is so light, I thought it would be nearly impossible to break - guess not!
boykster:
got mine today.....maiden flight was mostly spent trimming it and watching one of the cats alternate between super interested and totally freaked out! ;D
I was too impatient to wait for the green light to come on (while charging) does it actually come on?
Texasmame:
--- Quote from: boykster on October 26, 2006, 08:38:42 pm ---got mine today.....maiden flight was mostly spent trimming it and watching one of the cats alternate between super interested and totally freaked out! ;D
Yeah, it should as soon as it's plugged in. You have to leave the control on to charge but turn the chopper off. . .
boykster:
--- Quote from: Texasmame on October 26, 2006, 09:13:37 pm ---
I realized that shortly after i posted here, I left it plugged in (controller off) for about an hour and it still was dead :banghead: so I actually read the instructions ;)
Such a FUN little toy. We have vaulted ceilings in our living room so I got lots of room to fly! The cats love it...
Edgedamage:
--- Quote from: Zakk on October 06, 2006, 01:41:27 pm ---
--- Quote from: hnugz on October 06, 2006, 01:20:00 pm ---that heli looks like a lot of fun. it doesnt appear to have the bar things on the bottom for rescue missions though, dang!
I don't think you'd rescue more than a marshmallow with it, you would need one of those crazy jedi choppers from a couple of threads up to rescue even a GI Joe.
