Author Topic: GGG Ice Trackball and Apache Spinner  (Read 1785 times)
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« on: September 30, 2006, 08:40:10 am »
I am getting ready to make my 3rd control panel for my cocktail table and want to make sure I understand this.
I plan on using GGG Ice Trackball and the Apache Spinner.  Is this all I need to connect it?  I understand I plug in a trackball to the spinner.
OR
If I use the the spinner from GGG will the tops from Apache controls work?  I can hook it trackball to the GGG spinner also right?
« Last Edit: September 30, 2006, 08:56:46 am by squirrellydw »
I b**ch. People listen!!
apachecontrols
  • Last login:June 07, 2010, 09:03:08 pm
Re: GGG Ice Trackball and Apache Spinner
« Reply #1 on: September 30, 2006, 09:17:07 am »
The GGG Ice Trackball should be able to connect to the Apache Controls (primary) without any difficulty, provided the GGG unit will allow for +5, GND as inputs and send outputs for S1 and S2 (signals 1 and 2) - This is a typical configuration for trackballs. Check the online PDF reference manual on the AC website for details on how this would work.
  http://www.apachecontrols.com/manuals/ApacheControlsBlackhawk.pdf
Since most of our trackball testing was with HAPP standard trackballs, I'll let Randy T explain more to see what additional thoughts he might share on this topic. :)
To answer part 1 of the second question, yes. The knobs from Apache Controls are compatible with any 1/4" shaft spinner out there today. As for part 2 of your question, not sure if a trackball can be connected to the GGG spinner control circuit. Again, I'll defer that to Randy.
Let me know if you have any additional questions.
   David
Apache Controls, LLC
Honeoye Falls, NY (USA)
ONLINE: www.apachecontrols.com
EMAIL: support@apachecontrols.com
http://www.apachecontrols.com/ApacheControlsSkyScraper120x240.jpg
RandyT
  • Last login:Today at 11:46:17 am
    • GroovyGameGear.com
« Reply #2 on: September 30, 2006, 11:38:38 am »
The Electric ICE trackball has it's own interface.  It is an Opti-Wiz based board and allows for connection via USB or PS/2 (with appropriate adapter).  It does not need to be attached to a spinner, nor any other interface to function.
Yes, a number of gamers are using this configuration for their controls.  The standard Opti-Wiz to Trackball cable works for spinners with Z selected as their axis of operation.
RandyT
squirrellydw
« Reply #3 on: September 30, 2006, 10:06:47 pm »
OK Randy, do I just need to order the trackball and your spinner?  I would want USB.  Should they all be the Number 1 device??  It will be the only trackball and spinner I use?
RandyT
« Reply #4 on: October 01, 2006, 11:05:18 am »
Yes, they will both run on their own and can both be device number 1.  The only time you would want a device two of any of the USB products is if you already had another of that same type of product (IE. 2 spinners, 2 trackballs, 2 GP-Wiz, etc.)
Even though the optical controls are based on the Opti-Wiz, each product group has been given its own product ID so there is no confusion at the OS level.  An Opti-Wiz won't conflict with a TurboTwist spinner which won't conflict with an Electric ICE Trackball, and so-on.
RandyT
squirrellydw
« Reply #5 on: October 01, 2006, 11:12:42 am »
thanks, you will be getting an order from me soon  :)
