Main > Main Forum
4-way stick in software?
Pages: << < (2/6) > >>
_Iz-:
In mame, search src\inptport.c for "sticky" to find out more info on the 4-way on 8-way stuff...
(steady key is the debounce option)
u_rebelscum:
Mame currently does the first method for inputs compiled with the 4way flag, and the second way for the sticky option, IIRC.
pragma:
Could you tell me more about the 4way flag and how to use it?
Paul
seaner:
--- Quote from: seaner on March 21, 2003, 03:58:11 pm ---Has anyone considered turning an 8-way stick into a 4-way in software?  Has anyone tried it?  Success?  Miserable failure?
Since I designed my own keyboard encoder, this is obviously an option for me, rather than eating up panel space for dedicated 4-way sticks.
If anyone cares to know.. a firmware solution works dandy.  I put a toggle switch on my panel.  Flipping it puts all of my sticks into 4-way mode.  It may not feel like a restricted 4-way stick, but no more pesky diagonals now on pacman, etc.
u_rebelscum:
--- Quote from: pragma on March 21, 2003, 08:30:18 pm ---Could you tell me more about the 4way flag and how to use it?
You have to put it in the driver source file and can't change it (except by recompiling again).
Example straight from pacman.c:
PORT_BIT( 0x01, IP_ACTIVE_LOW, IPT_JOYSTICK_UP    | IPF_4WAY )
The biggest problem with it is with 8way sticks with huge diagonals.  You are pushing up, but not quite straight up, and accidentally move into the diagonal up-right.  Mame thinks, "oh, he's switching to right, so I'll just read this as right.  You can look at how mame handles the 4way flag in src/inptport.c, ScanJoysticks() function.  Pretty good documentation in the code on this, IMO.
Restricter plate is the best way it you have a choice, though.
Go to full version
