Main > Main Forum
4-way stick in software?
RandyT:
--- Quote ---That's not sticky mode.
So what exactly is the difference between:
"while any direction is asserted, its adjacent diagonals are masked until the initial direction is released."
and
"if push N, mame keeps sending North until N is not pressed. So, pressing N then NW or NE is still N, and W then NW is still W."
RandyT
u_rebelscum:
--- Quote from: RandyT on March 25, 2003, 07:38:28 am ---
and
Ah, misunderstanding: His example he shows in the table doesn't match his summary. I was going off the table, you were going off the summary.
His table is selective, sticky mode isn't. A better summary sentence:
"While a direction is asserted, one of its adjacent diagonals is masked until the initial direction is released. All directions masks are either clockwise or counter-clockwise from the direction."
But that's two sentences, and not as as summary. ;)
RandyT:
--- Quote from: u_rebelscum on March 25, 2003, 07:46:20 pm ---
and
Not trying to be nitpicky, but in seaner's defense, he called it out as a progression, not a table. As a progression, it's pretty clear what he meant.
But no bigee :)
RandyT
u_rebelscum:
--- Quote from: RandyT on March 25, 2003, 08:12:32 pm ---Not trying to be nitpicky, but in seaner's defense, he called it out as a progression, not a table. As a progression, it's pretty clear what he meant.
You right. I thought it was a table for some reason. :-[
Maybe I thought that because I set up mame that way, and it works much better than either sticky keys or mame's current 4way; a little "twisted" (~23.5 degrees off vertical), but not too sensitive, not too slow. [hides head] ;)
Going to get me a restrictor plate for better play at some point, though.
seaner:
hehe.. not to flog a dead horse here, but the implementation is more along the lines of:
- 4 bits per nibble to represent a joystick
- if any 2 bits are asserted, mask off the new inputs and replace the 2 bits with the previous 2 bit value from that position:
or:
if ((newinput & 0x3)==0x3)
newinput = (newinput & 0x3) | (oldinput & 0x3);
... repeat for mask of 0x6, 0xc, 0x9
oldinput = newinput;
I'm curious why u_rebelscum is having a problem with the alignment from center though.. off by 23.5 degrees? Is this due to the fact that the levers on the microswitches extend at a slight angle from vertical or horizontal? I've noticed a similar problem.. I may solve it by just giving the ends of the metal springs a minor bend. This of course isn't a 4-way/8-way problem, it's a problem in general I've noticed with at least one of my x-arcade sticks.
