Main > Everything Else
Fixing clearcoat damage
Pages: << < (6/6)
DrewKaree:
--- Quote from: USSEnterprise on September 30, 2006, 07:32:50 am ---oops, wrong thread
You think it's any easier for US to keep up with? :dizzy: :laugh2:
USSEnterprise:
valid point
psik0tik:
--- Quote from: Brax on September 28, 2006, 10:44:44 am ---
--- Quote from: DrewKaree on September 27, 2006, 10:32:48 pm ---Say, are they still painting vintage bikes with catalyzed polyurethane?  That'd be great if they were, so we'd know that rattle-can enamel would definitely work, instead of guesstimating.....what kinda primer do you use to make those two dissimilar products work well together?
The most exotic paint I've come across to date is a two-stage Dupont Imron. I usually use an enamel for repairs. (enamel also comes in the pearl colours some european frame manufacturers use.) I restore steel lugged frames so dissimilar paints aren't an issue since I can sand down to bare metal between the lugs, use an etching primer, enamel colour coat and then the clear.
Imron is a single stage paint...2 stage would be basecoast clearcoat...sorry I own a body shop had to put my input in...and if imron 5.0 is the most exotic then you have been out of the loop forever :)
Pages: << < (6/6)
Go to full version
