Author Topic: Help me How do I easily remove "filter out" non USA roms from various Sets ??  (Read 1199 times)
mrclean
    • Guscade
Basically For instance If I have kega running as my emu with mamewah as the front end ill have like 8,478 sega games come up.. some have <h1> <beta> <jap> ones etc.. basically how do i trim that list down to only [!} verified USA list without doubles is there any easy way to do this.. not just with Sega But also NES etc.. ???
2,370,650 Gun.Smoke
loadman
  • Last login:August 17, 2020, 03:23:55 am
    • MaLa
You said 'For instance' , and I don't know how to do this for MameWah, in mala you use the GameList editor.
http://mala.arcadezentrum.com/malagamelist.html
[EDIT] IGNORE THAT. I missread your question. I should wake up properly before posting  :-(
« Last Edit: September 23, 2006, 07:38:38 pm by loadman »
  • Last login:May 03, 2024, 11:58:33 pm
That would just clean up the name (unless I am misunderstanding).  He wants to filter out the non-usa roms.
The easiest way is to run them through goodtools.  By default it'll seperate them into folder by country and then you have a manual filter by directory.
mrclean
    • Guscade
exactly how do i do that ? with goodtools ?
2,370,650 Gun.Smoke
Santo8742
  • Last login:September 11, 2015, 06:48:39 pm
If you know how to use goodtools already then just select the dir option before you start. This will automatically separate the games into various region folders. If you've never used goodtools go here: http://www.allgoodthings.us/mambo/index.php?option=com_simpleboard&Itemid=42
mrclean
    • Guscade
thanks ! downloaded a GUI and seemed to work its good to trim my list down to games that i'll actually consider playing!
2,370,650 Gun.Smoke
