Author Topic: ZSNES and Mamewah  (Read 2257 times)
Jedirampage
  • Last login:July 08, 2008, 06:54:08 pm
ZSNES and Mamewah
« on: September 23, 2006, 04:54:46 pm »
Can anyone help me with configuring znes to work with mamewah, I loaded the emulator into mamewah however I can't play any games.  Everytime i try to load a game nothing happens.
my58vw
  • Last login:July 21, 2010, 01:22:43 pm
Re: ZSNES and Mamewah
« Reply #1 on: September 23, 2006, 06:35:58 pm »
I am having the exact same problem running mamewah 1.61 with CP's ini files modified to run on 1.61. I can run the games outside the emulator just fine. I can get the dos version to work just fine although the emulation is very very slow.
In the windows version of zsnesfe (modified version) there is no emulator shut off comand like in the dos version.
Is their another emulator that will work for snes in mamewah?
« Last Edit: September 23, 2006, 06:38:33 pm by my58vw »
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #2 on: September 23, 2006, 07:07:38 pm »
You guys are in luck!!
I had massive problems with ready-made .ini files for MAMEWAH and a lot of people seemed reluctant to post their .ini files. Others just couldn't identify problems. However, after a bit of tinkering I identified some problems with the file and modified it slightly. Turns out the 'executable commandline format' was wrong!
Stick with ZSNES, it is brilliant once it is working. Just make sure you get the modified version from the cpviewer website (jcrouse's) which enables 'Escape' to exit the emulator, rather than call up the menu.
One problem I had with it was the speed, which seemed slower under MAMEWAH, but isn't really. What I found though was I had a delay between button presses and the action on screen. No-one could explain it, but in the end it turned out to be as a result of triple buffering in the 800x600 resolution I had it in. I shut this off and it was fine! Here is my .ini file. All you should need to change is the 'rom folder location' and the 'emulator executable location':
### SNES.ini (mamewah v1.61) ###
emulator_title                            SNES
### List Generation Settings ###
rom_path                                  c:\SNES\roms
rom_extension                             ZIP
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       c:\SNES\zsnesw.exe
commandline_format                        "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
alt_commandline_format_1                  "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
alt_commandline_format_2                  "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               0
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
Try that and see if it works. I found a few of the .ini files I downloaded were slightly wrong, so if you struggle with any others just post it here and I'll see if I have it.... :)
my58vw
« Reply #3 on: September 23, 2006, 07:59:14 pm »
It works!!!  ;D
I don't know how much to thank you for that one...  I was up litteraly all last night trying to figure that one out!
Thanks again
Jedirampage
« Reply #4 on: September 23, 2006, 08:19:29 pm »
For mamewah v.97, do i edit the .cfg file?  as I don't see anything in the ini folder
Turnarcades
    • Turnarcades
« Reply #5 on: September 24, 2006, 08:21:08 am »
Er, yes Jedi, I think so.
You won't be able to copy this text directly into your config file though, as some of the lines are different for the older MAMEWAH version. Just copy any relevant lines over to your config file individually.
I know you probably don't want to hear this, but I'm assuming you only went for MAMEWAH 0.97 'cos there was a config tool for it. I found I had lots of trouble with this as the tool just adds another element of confusion to the less-than perfect code in this version. You may do well to upgrade to a newer MAMEWAH version as there is much more support for it and the base structure of the installation is now drastically different to 0.97. It is better laid-out and makes for less errors.
Plus, you can get results in the forums like the guy I just helped out!
Jedirampage
« Reply #6 on: September 24, 2006, 02:09:49 pm »
Yeah i just realized that and I have switched to Mamewah v 1.62 beta, I currently am trying your .ini file and will be replying back by the end of the day with the results.
Jedirampage
« Reply #7 on: September 24, 2006, 02:21:50 pm »
I still can't get anything to work, here is a copy of my .ini file if it helps
### SNES.ini (mamewah v1.62) ###
emulator_title                            SNES
rom_path                                  C:\SNES\ROMS
rom_extension                             zip
dat_file
nms_file
catver_ini_file
pre_emulator_app_commandlines
emulator_commandline                      C:\SNES\zwsnes.exe
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       C:\SNES\artwork
movie_preview_path                        c:\mame\previews
movie_artwork_no                          1
enable_fuzzy_search                       0
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                gamelist_slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
music_path
current_list                              0
unclet
« Reply #8 on: September 24, 2006, 04:24:23 pm »
It would seem to me the "emulator_commandline" should be the following:
C:\SNES\zwsnes.exe "[rompath]\[name].[romext]"{nodosbox}{safelaunch}
Your current "emulator_commandline" just specifies the EXE to use but does not tell the zsNes emulator where the ROM file is located ......
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #9 on: September 24, 2006, 04:26:47 pm »
Mines working sweet!
### snes.ini (mamewah v1.61) ###
emulator_title                            snes
rom_path                                  c:\emulators\snes\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file
emulator_executable                       c:\emulators\snes\zsnesw.exe
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
artwork_1_image_path                      c:\emulators\snes\snap
movie_preview_path                        i:\zsnesw\videos
movie_artwork_no                          1
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
ipc_file_or_path
app_1_executable
app_2_executable
app_3_executable
auto_launch_apps
music_path                                c:\mamewah\music
lcd_fe_text
current_list                              0
My old user name was marlborroman13, but I kicked the habit many years ago!
unclet
« Reply #10 on: September 24, 2006, 04:29:29 pm »
marlborroman13:
Your using v1.61 of MameWah .... he wants to use v1.62 instead ....   I believe my recommendation above should help out ....
Jedirampage
« Reply #11 on: September 24, 2006, 11:11:32 pm »
okay i've tried it in version 1.61 to no results here is the new .ini file
emulator_title                            SNES
rom_path                                  C:\DOCUMENTS AND SETTINGS\HP_OWNER\MY DOCUMENTS\ROBBIE STUFF\ARCADE\EMULATORS\SNES\ROMS
rom_extension                             zip
dat_file
nms_file
catver_ini_file
emulator_executable                       C:\DOCUMENTS AND SETTINGS\HP_OWNER\MY DOCUMENTS\ROBBIE STUFF\ARCADE\EMULATORS\SNES\zwsnes.exe
artwork_1_image_path                      c:\mame\snap
movie_preview_path
movie_artwork_no                          1
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
scr_file
ipc_file_or_path
app_1_executable
app_2_executable
app_3_executable
auto_launch_apps
music_path
lcd_fe_text
current_list                              0
The thing is slightly jumbled because of the long paths, the znes version that I am using is 1.36, please let me know if there is some type of supersecret command line version or something else  out there.  is there any extra configuration i need to do in zsnes?  anytime I go to play a game the screen does nothing.
unclet
« Reply #12 on: September 25, 2006, 07:05:15 am »
I would not recommend going back to v1.61 since a lot of changes went into v1.62 and it has been out for awhile now so it is stable in my opinion.
Anyway, if you start MameWah and get a blank screen then try all combinations of the following on your command line to see if it fixes your problem:
Change {nodosbox} to {dosbox} and\or change {safelaunch} to {nosafelaunch}
(try all combinations ....)
biron
  • Last login:August 20, 2007, 05:09:14 pm
  • Biron
    • my cab
« Reply #13 on: September 25, 2006, 10:22:37 am »
just to clarify.. you don't need to use any "modified version" of zsnes to use with mamewah. you can use the standard build.
here you can find all different builds: http://zsnes.ipherswipsite.com/
zsnes september 4 is the latest build..
to enable esc to exit, just make sure you disable the gui in the inifile
Uppsala University.
Jedirampage
« Reply #14 on: September 25, 2006, 10:33:40 am »
you can disable the gui?  am i suppose to do that? if so how, that may be part of my problem
Zeosstud
  • Last login:April 17, 2024, 03:12:48 pm
« Reply #15 on: September 25, 2006, 04:06:57 pm »
This works for me and Mamewah 1.62b12
### SuperNintendo.ini (mamewah v1.62) ###
emulator_title                            SuperNintendo
rom_path                                  C:\zsnesw\Roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file
emulator_commandline                      C:\zsnesw\zsnesw.exe "[rompath]\[name].[romext]"{dosbox}{safelaunch}
artwork_image_paths                       C:\zsnesw\Snaps
movie_preview_path
movie_artwork_no                          1
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
music_path
current_list                              1
Hope it helps,
Zeosstud
Jedirampage
« Reply #16 on: September 26, 2006, 02:30:32 am »
IT WORKED!!!!!, in both version of mamewah (1.61, and 1.62) I had to upgrade to the latest version of zsnes because the one I had did not let you disable the gui.  Thanks for everything guys, I just have one final question, when i open a game how do i get it to open in full screen.  Right now it only opens in a minimized window.
postalp123
  • Last login:March 18, 2024, 09:07:50 pm
  • Retro-gamers don't just play, they reminisce.
« Reply #17 on: September 26, 2006, 12:29:11 pm »
Look in the ZWSNES options under display, there should be a fullscreen option, stretch to fill scrren will help to.
Zeosstud
« Reply #18 on: September 26, 2006, 12:30:06 pm »
In the zsnesw.cfg file there are a BUNCH of video modes with a corresponding number assigned to them.  You could adjust whatever the default is now to whatever you want it to be.  Personally on my son's machine which only has a 15" monitor I have it open in vidoe mode 7 which is 640x480 Full Screen.  I am sure you will be able to test alittle and find which video mode works best for you.  Below is the video part of my zsnesw.cfg file, hope it helps you.
; Video Mode, 0 - 32
;   0 = 256x224 R WIN         1 = 256x224 R FULL
;   2 = 512x448 R WIN         3 = 512x448 DR WIN
;   4 = 640x480 S WIN         5 = 640x480 DS WIN
;   6 = 640x480 DR FULL       7 = 640x480 DS FULL
;   8 = 640x480 S FULL        9 = 768x672 R WIN
;   10 = 768x672 DR WIN       11 = 800x600 S WIN
;   12 = 800x600 DS WIN       13 = 800x600 S FULL
;   14 = 800x600 DR FULL      15 = 800x600 DS FULL
;   16 = 1024x768 S WIN       17 = 1024x768 DS WIN
;   18 = 1024x768 S FULL      19 = 1024x768 DR FULL
;   20 = 1024x768 DS FULL     21 = 1024x896 R WIN
;   22 = 1024x896 DR WIN      23 = 1280x960 S WIN
;   24 = 1280x960 DS WIN      25 = 1280x960 S FULL
;   26 = 1280x960 DR FULL     27 = 1280x960 DS FULL
;   28 = 1280x1024 S WIN      29 = 1280x1024 DS WIN
;   30 = 1280x1024 S FULL     31 = 1280x1024 DR FULL
;   32 = 1280x1024 DS FULL
VideoModeWin = 7
Zeosstud
Turnarcades
    • Turnarcades
« Reply #19 on: September 27, 2006, 02:03:07 pm »
Yeh you can ether do it manually in the ZSNES config file or you can temporarily enable the GUI to do it from there, then turn it back off again once you're done. I'd advise turning triple buffering off still, as it caused problems in response times with my controls.
Jedirampage
« Reply #20 on: September 27, 2006, 03:32:40 pm »
will that also help the emulator to not look so pixelated, I remember SNES games looking much better
Turnarcades
    • Turnarcades
« Reply #21 on: September 28, 2006, 05:03:21 am »
It can do. If you look at the 'Display Options' Window in the ZSNES GUI menus there are a few extra options at the bottom like 'SAI', 2xSAI, Interpolation and a few other effects. Try them all to see which effect you like best. If you use a TV, I wouldn't bother, but the 'Interpolation' effect looks good (when the games are running-ignore how it looks on the menu) if you are using a monitor. The more effects you use though, the higher the chance of slow-down. That's why I recommend avoiding the triple-buffering.
If you are using the DOS ZSNES by the way, none of these options will be available, so bear that in mind.
